P.S. feeling overwhelming guilt for being the cause of this being
out-of-order yet again. If there’s anything I can do to help with the
repair, let me know.
Hmm, I appear to have lost my ability to construct sentences. Sorry
about that, I’m blaming the baby/cold/anything else I think I can get away
with blaming.
tamarisk kay
11 March 2015 10:46
That wasn’t me it was Bob. (Although I did make a joke about you
attempting to break it in the other thread
Sounds like something’s come loose Simon we’ll have an investigate today.
Hopefully it’s a simple thing to fix.
I’m also starting to suspect this laser is plotting against us!
T.
simon_...@cwgsy.net
10 March 2015 21:29
Hi
In reply to Tas, it worked fine when I started and there were no problems
until my third piece of ply.
On the third piece, I sent to file from from laptop with Excecute, walked
over to the laser cutter and saw that the screen said Run, as per normal.
However, when I pressed the small black button in the middle to the key pad
nothing happened. After a short pause the screen returned to Main.
I Executed the file from VisiCut again, but once again nothing happened
and the screen returned to Main.
I turned the machine off, waited a bit and then tried again. The same
thing happened. There were no strange noises, grating or grinding sounds.
The only thing that I’d done differently from the first two pieces was to
lower the speed of the cut down from 10 to 9 because the laser hadn’t gone
all the way through on some of the curves. However, I wouldn’t think that
would stop the machine from working at all.
Yours sorrily
Simon
Hi Simon,
What was happening? (Or not happening as it were)
email to hacman+un...@googlegroups.com.
Bob Clough
10 March 2015 20:38
Hi Simon,
simon_...@cwgsy.net
10 March 2015 20:12
Unfortunately, the laser has stopped working again.
I downloaded a newer version of VisiCut and also the settings. I was able
to cut two bits, but couldnt’ cut any more.
The first bit it cut really well, so hoping it’s not a major problem.
Simon (FG)
The laser is currently working, but please read the following:
We’ve renumbered the network, so you’ll need to update your visicut
settings before using the laser cutter.
Either do a git pull, or click Edit > Settings > Download Recommended
Settings, then select “United Kingdom, Manchester, Hackspace” in visicut.
The latest settings will be downloaded and installed.
If you dont have Edit > Settings > Download Recommended Settings,
update your version of visicut.
Bob Clough
10 March 2015 11:34
If you dont have Edit > Settings > Download Recommended Settings, update
