Broken Lighting Desk
AS you may (probably not) have noticed, I have not been into the space
recently. The reason for this as you may (probably not) know is mainly due
to the school production occurring, and me rigging the stage lights /
programming the lighting desk. The school’s productions are
remarkably professional for a school, and as such there is a lot of this
kind of work to do. Today I finished the last bits of tweaking the
programming (programming meaning setting up combinations of lights on a
controller desk, not coding), and all is was going remarkably well. Until,
a few seconds after I finished, the desk completely died. The dress
rehearsal is tomorrow so I have about 4 hours to fix it :frowning: I am asking
for any general advice on what may or may not be the problem here.
Ok, a bit of brief history about the problem.
  1. About a week ago, the desk started crashing more than usual (locking up,
    requiring reboot, screen still active but frozen, and LEDs on but again
    frozen)
  2. Avolites (the company that makes it) said that this was a common
    problem, and that you should remove the graphics card to fix it.
  3. The graphics card is a PC graphics card, for connecting to an external
    monitor if required,
  4. We removed it and the problem went away - I noticed that the desk uses a
    bog-standard ATX supply
  5. Tonight we had the technical rehearsal, all went well
  6. After the rehearsal, doing a bit of tweaking without the director, the
    DMX output cut out (essentially as though disconnected) - a reboot fixed
    this
  7. Doing some tweaking with the director, all was going well.
  8. Tweaked the last scene - all working
  9. Looked up to ask director if happy with scene
  10. Looked down - desk gone to shit
And what does “gone to shit” actually mean in this case
  1. Desk screen (not external monitor, one of those white and purple ones)
    blank
  2. LEDs frozen, but significantly dimmer than normal
  3. There is a plug in lamp that fixes to the top of the desk, which shines
    light onto the desk, so the operator can see what he is doing. - this went
    slightly dimmer
  4. I turned the desk off, waited a few seconds, then turned it on.
  5. Screen still blank - DMX as though disconnected - nothing responsive -
    all LED indicator lights off
The lamp has a switch, with Dim, Off and Full (in that order)
When on dim, the screen backlight was at its dimmest
When off, the screen backlight was a bit brighter
When on full, the screen backlight was noticeably brighter
Apparently, there are a number of internal fuses, one of which is on the
DMX output line.
What I intend to do tomorrow
  1. See if the fairies have magically fixed it in the night
  2. Check Fuses
  3. Probe the power supply / swap it out for another
  4. Look for shorts
  5. Look for bad caps
The technical officer from a rental agency called HSL is coming in tomorrow
(with a replacement desk to rent) to have a look at it as well
It is highly unlikely he will fix it (not that kind of technical officer).
We need to get the desk working for about 10 mins so we can copy the show
onto a floppy (yes, its that old) and transfer it onto a good desk.
The desk is an Avolites Pearl 2000
The dress rehearsal is tomorrow night, the public one the day after.
I have 2 one-hour windows tomorrow during the school day, and about an hour
the day after.
Thanks in advance for any help :smiley:
George
Hi George,
Sounds very much like a dodgy supply to me. That’s quite an old unit. I
notice there is a 2011 dated firmware update available for that unit too.
Might be worth changing the supply and updating the firmware.
    up, requiring reboot, screen still active but frozen, and LEDs on but again
    frozen)
    a bog-standard ATX supply
    this
    blank
    slightly dimmer
DMX output line.
  2. Check Fuses
  4. Look for shorts
tomorrow (with a replacement desk to rent) to have a look at it as well
hour the day after.
George
To view this discussion on the web, visit
https://groups.google.com/d/msg/hacman/-/l2eFUOc2p9MJ.
Yeah, I’m going to try that, though I can’t update the firmware until it is
functional :frowning:
Also thinking if it is a bad supply then it’s likely it has taken a few
caps with it too…On 25 November 2012 22:28, Jon Wilson fast21@gmail.com wrote:
Hi George,
Jon Wilson
    frozen)
    this
    blank
    shines light onto the desk, so the operator can see what he is doing. -
    this went slightly dimmer
DMX output line.
  2. Check Fuses
  4. Look for shorts
hour the day after.
George
Days I wish I had an ESR meter… :-)On 25 November 2012 22:32, Jon Wilson fast21@gmail.com wrote:
caps with it too…
Hi George,
Jon Wilson
    frozen)
    external monitor if required,
    uses a bog-standard ATX supply
    the DMX output cut out (essentially as though disconnected) - a reboot
    fixed this
    ones) blank
  • all LED indicator lights off
DMX output line.
  2. Check Fuses
  4. Look for shorts
officer).
show onto a floppy (yes, its that old) and transfer it onto a good desk.
hour the day after.
George
usually bad caps are quite easy to spot, they’ll have either bulged or
leaked.On 25 November 2012 22:44, George Ainscough dashroom66@gmail.com wrote:
Days I wish I had an ESR meter… :slight_smile:
caps with it too…
Hi George,
Jon Wilson
    frozen)
    fixed this
    ones) blank
the DMX output line.
  2. Check Fuses
  4. Look for shorts
officer).
hour the day after.
George
Yeah, though I’ve done lots of these where I’ve replaced those ones, then
it still doesn’t work, then I’ve had to go through them with an ESR meter,
and then go back and order more, pissing me of SOOOO much. Don’t have time
for 2 orders :slight_smile:
Hope they are all visibly crap :slight_smile:
leaked.
caps with it too…
Hi George,
Jon Wilson
    (locking up, requiring reboot, screen still active but frozen, and LEDs on
    but again frozen)
    fixed this
    ones) blank
    though disconnected - nothing responsive - all LED indicator lights off
  2. Check Fuses
  4. Look for shorts
officer).
hour the day after.
George
All fixed.
New power supply, some bodge wires, resistors and caps, and it is good as
new.
Thanks for the help :smiley:
GeorgeOn 25 November 2012 22:51, George Ainscough dashroom66@gmail.com wrote:
George
leaked.
caps with it too…
Hi George,
I notice there is a 2011 dated firmware update available for that unit too.
Jon Wilson
space recently. The reason for this as you may (probably not) know is
mainly due to the school production occurring, and me rigging the stage
lights / programming the lighting desk. The school’s productions are
    but again frozen)
    fixed this
    ones) blank
  2. Check Fuses
  4. Look for shorts
officer).
an hour the day after.
George
Good to hear. :slight_smile:
Did you stick the firmware update on it? Or was it already up to date.
Jon WOn 26 November 2012 23:24, George Ainscough dashroom66@gmail.com wrote:
All fixed.
new.
George
George
leaked.
few caps with it too…
Hi George,
Jon Wilson
    but again frozen)
    director, the DMX output cut out (essentially as though disconnected) - a
    reboot fixed this
    ones) blank
  2. Check Fuses
  4. Look for shorts
officer).
George
It’s on 2004
May update, but te show is in an hour:-D
Thanks
Jon W
All fixed.
new.
George
then it still doesn’t work, then I’ve had to go through them with an ESR
meter, and then go back and order more, pissing me of SOOOO much. Don’t
have time for 2 orders :slight_smile:
George
leaked.
Hi George,
unit. I notice there is a 2011 dated firmware update available for that
unit too. Might be worth changing the supply and updating the firmware.
Jon Wilson
    but again frozen)
    desk uses a bog-standard ATX supply
    reboot fixed this
    ones) blank
on the DMX output line.
  2. Check Fuses
  4. Look for shorts
officer).
the show onto a floppy (yes, its that old) and transfer it onto a good desk.
George
Ah… best not to tempt fate just before the show. lol. :slight_smile:
Jon WOn 27 November 2012 17:49, George Ainscough dashroom66@gmail.com wrote:
It’s on 2004
Thanks
George
Jon W
All fixed.
as new.
George
George
leaked.
Hi George,
Jon Wilson
    but again frozen)
    common problem, and that you should remove the graphics card to fix it.
    reboot fixed this
    purple ones) blank
    which shines light onto the desk, so the operator can see what he is doing.
  • this went slightly dimmer
  1. I turned the desk off, waited a few seconds, then turned it on.
  2. Screen still blank - DMX as
  2. Check Fuses
  4. Look for shorts
officer).
after.
about an hour the day after.
George
