Hi there, (please let me know if this post should be somewhere else, or move if needed)
During lockdown i bought a prover 3018 cnc router - basically to make boxes with, i thought about a laser cnc but decided i would like to cut deeper wood, so went with the drill.
I can’t use it! everything looks terrible, bad wood tearing on everything. So I was wondering does the hackspace have a router like this? - does anyone use something like this and could spare me a bit of time at the hackspace to run through some of the basics with me?
I’ve had success with B&M bamboo cutting boards.
The top left cutters in the first pic of the link you sent will be OK but still expect fuzziness in soft wood.
Rough with up down cutter then finish with high speed slow feed fine cutter when doing carving.
