digital measuring callipers
I borrowed a set from the hackspace, however they seem to be badly out of
alignment. Out of three tests measuring and returning to zero I’ve had
+/-7mm difference each time.
Is there any way of fixing, or should I just throw them?
Last time I used them they were fairly accurate, but that was a long time ago. It feels silly suggesting this to you, but did you check the battery?
Will.> On 15 Mar 2015, at 13:50, Ben Dooks bjdooks@googlemail.com wrote:
I borrowed a set from the hackspace, however they seem to be badly out of alignment. Out of three tests measuring and returning to zero I’ve had +/-7mm difference each time.
signature.asc (841 Bytes)
there may be >1 set in the space.
Battery seems ok, but don’t have any spares here.On 15 March 2015 at 14:02, Will Jessop will@willj.net wrote:
Will.
yepp,
i also noticed that they are fairly inaccurate.
maybe this could help:
https://www.woodgears.ca/caliper/index.html
the lidl in liverpool just had new calipers for around 10 quid…
maybe it’s easier buying a new one.
Will.
