DIY Help - Flanges
http://media.toolking.com/catalog/product/cache/1/image/800x600/9df78eab33525d08d6e5fb8d27136e95/L/D/LDR_310F-2_2-inch_Black_Floor_Flange.jpg
Hi all.
I’m trying to purchase something known as a “galvanized flange” but they
don’t seem to exist in the UK for what I want it for. Does anyone know if
they go by a different name?
Ideally I need a 35mm wide flange with four holes in it like that one, and
I need a piece of pip about 30cm long that will screw into it.
I’m trying to make a banner stand with this tutorial:
http://www.caerthe-sca.org/herald/article-40-dollar-banner-stand.html
I’ve spent so long googling I’m starting to resent the word flange now :frowning:
By a freak coincidence, I’m looking for something similar. The closest I’ve got so far is actually from a shop just round the corner on Thomas Street, and it’s this…
http://www.shopfittings-ltd.co.uk/shop-fittings-and-wall-display/chrome-tube/wall-mounted-chrome-tube-fittings/wall-socket-for-chrome-tube.html
It’s not threaded, but you can attach tube to it.
Also, you said ‘flange’.
SniggerDate: Mon, 23 Mar 2015 14:25:09 -0700
To: hacman@googlegroups.com
Subject: [HACMan] DIY Help - Flanges
Hi all.
I’m trying to purchase something known as a “galvanized flange” but they don’t seem to exist in the UK for what I want it for. Does anyone know if they go by a different name?
Ideally I need a 35mm wide flange with four holes in it like that one, and I need a piece of pip about 30cm long that will screw into it.
I’m trying to make a banner stand with this tutorial: http://www.caerthe-sca.org/herald/article-40-dollar-banner-stand.html
Try looking for kee clamps, they’re probably close to what you needOn 23 Mar 2015 21:25, “Bohemia Skye” bohemia.skye@googlemail.com wrote:
Hi all.
http://www.pipefittingsdirect.co.uk/contents/en-uk/d37_Flange.html
The sizes given are for the center hole, so the 15mm should be the closest
match.On 23 March 2015 at 21:25, Bohemia Skye bohemia.skye@googlemail.com wrote:
Hi all.
The center hole needs to be 35mm to accommodate a wooden rod. I found that last link but I couldn’t seem to find the matching pipe to go with it. Am I being dense?
That top link is looking good but I dont know if the screw fitting would be enough to hold the pole and banner up, given that it’ll be out in the wind.
lots to look at/think about. Thanks all.
You mean this pipe:
http://www.pipefittingsdirect.co.uk/contents/en-uk/d15.html ?On 24 March 2015 at 12:23, Bohemia Skye bohemia.skye@googlemail.com wrote:
Yep. Thats it! I don’t know why I couldn’t find it last night, I thought I’d been all over that website. Though its a but more expensive than I was hoping for.
These kee klamps seem to be a winner at the moment. Bob, do you know if there’s anything in the space that could cut the pipe to size? They sell it in meter lengths but I only need about a third of that.
I’m sure there must be but I’ve not done much with metal before.
What type of pipe is it?
We have some pipe cutters but a hacksaw with the correct blade will
probably be ok.
hoping for.
It says galvanized 3mm thick. But I messaged the seller and they’re going to cut it down for me :smiley: hooray!
Thank you all very much for answering my panicked questions!
