I’ve had a crack at making a library item for 4x6 key pad with adapted for
through hole addressable RGB LED’s.
Got to the stage of using the library in the schematic, I’ve found you can
connect all nets of same name.
https://lh3.googleusercontent.com/-wDt8o9ltTG0/Vl9CMhu2KnI/AAAAAAAAAEY/544XhF0lqEw/s1600/Screen%2BShot%2B2015-12-02%2Bat%2B18.53.03.png
I have 24 led’s in total, with four pins each, instead of drawing 96 little
electrical connections/nets on the and labelling them all, is there a way
to programatically to connect them all, or have I missed something in the
naming conventions somewhere?
Any help would be greatly appreciated!
Could you have included you schematics and board file?> On 2 Dec 2015, at 19:16, rich op richop88@gmail.com wrote:
I’ve had a crack at making a library item for 4x6 key pad with adapted for through hole addressable RGB LED’s.
Got to the stage of using the library in the schematic, I’ve found you can connect all nets of same name.
I have 24 led’s in total, with four pins each, instead of drawing 96 little electrical connections/nets on the and labelling them all, is there a way to programatically to connect them all, or have I missed something in the naming conventions somewhere?
