farnell order
I missed last weeks, so will be doing another one on Tuesday.
Ok I need:
http://uk.farnell.com/rubycon/25ml100mefc8x7/capacitor-100uf-25v/dp/8126399 x
2
http://uk.farnell.com/multicomp/bc337/transistor-npn-to-92/dp/1574379 x 5
(minimum)
http://uk.farnell.com/welwyn/mfp1-18r-ji/resistor-1w-5-18r/dp/1565352 x 10
(minimum)
http://uk.farnell.com/texas-instruments/tl431clp/shunt-reg-adj-2-5-36v-to-92-431/dp/1106038On Saturday, September 22, 2012 5:00:46 PM UTC+1, Ben Dooks wrote:
Ben Dooks, http://www.fluff.org/ben/ bjd...@googlemail.com <javascript:>
Ok I need:
2
(minimum)
10 (minimum)
ok, should have these in for Wednesday.
Ok I need:
2
(minimum)
10 (minimum)
2.53ukp, ex-vat (iirc)
I will be closing this at 16:30 on Tuesday, so anyone wanting stuff
please get an order in by then.
Ben,
Please can I have the following components:
http://uk.farnell.com/vishay-siliconix/irf540pbf/mosfet-n-100v-28a-to-220/dp/1653661
  • £0.67 - 4 off so - £2.68
http://uk.farnell.com/vishay-bc-components/ntcle100e3103jb0/thermistor-ntc/dp/1187031
£0.20 - 10 off so - £2.00
I’ll sort you out with cash on Wednesday,
Ben,
4.68, think it is ex-vat
Ok…charge me vat on that -
4.68/100 = 0.0468
0.0468 * 20 = 0.936
4.68+0.936 = 5.616…
I will have £5.62 for you on Wednesday…
AlexOn 24 September 2012 22:53, Ben Dooks bjdooks@googlemail.com wrote:
On 24 September 2012 22:50, Alexander Lang alexanderlang1980@gmail.com wrote:
Ben,
4.68/100 = 0.0468
0.0468 * 20 = 0.936
4.68+0.936 = 5.616…
it would be easier to do x1.2 :wink:
Ben,
“Line No.”,“Order Code”,“Qty”,“Description”,“Mftr. & Part No.”,“RoHS”,“Unit
Price”,“Avail.”,“Line Price”,"Line note"
1,“1516301”,“200”,“CRIMP TERMINAL, XH, 28-22AWG”,“JST (JAPAN SOLDERLESS
TERMINALS) - BXH-001T-P0.6”,"YES “,“0.04”,“In Stock”,“8.0”,”"
2,“1516278”,“10”,“HEADER, VERTICAL, 4WAY”,"JST (JAPAN SOLDERLESS TERMINALS)
  • B4B-XH-A (LF)(SN)","YES “,“0.14”,“In Stock”,“1.4”,”"
    3,“1516277”,“20”,“HEADER, VERTICAL, 3WAY”,"JST (JAPAN SOLDERLESS TERMINALS)
  • B3B-XH-A (LF)(SN)","YES “,“0.109”,“In Stock”,“2.18”,”"
    4,“1516276”,“20”,“HEADER, VERTICAL, 2WAY”,"JST (JAPAN SOLDERLESS TERMINALS)
  • B2B-XH-A (LF)(SN)","YES “,“0.103”,“In Stock”,“2.06”,”"
    5,“1516264”,“10”,“CONNECTOR HOUSING, 2WAY”,“JST (JAPAN SOLDERLESS
    TERMINALS) - XHP-2”,"YES “,“0.035”,“In Stock”,“0.35”,”"
    6,“1516265”,“20”,“CONNECTOR HOUSING, 3WAY”,“JST (JAPAN SOLDERLESS
    TERMINALS) - XHP-3”,"YES “,“0.045”,“In Stock”,“0.9”,”"
    7,“1516266”,“20”,“CONNECTOR HOUSING, 4WAY”,“JST (JAPAN SOLDERLESS
    TERMINALS) - XHP-4”,"YES “,“0.063”,“In Stock”,“1.26”,”“
    8,“1777101”,“1”,“TERMINAL BLOCK, PCB, 2.54MM, 8WAY”,“WAGO - 233-508.”,“YES
    ”,“2.59”,“In Stock”,“2.59”,”"
    9,“1675765”,“10”,“HEADER, SQUARE PIN, 2.54MM, 3WAY”,“MULTICOMP -
    MC34631”,"YES “,“0.176”,“In Stock”,“1.76”,”"
    10,“1675766”,“10”,“HEADER, SQUARE PIN, 2.54MM, 4WAY”,“MULTICOMP -
    MC34633”,“YES “,“0.24”,“In Stock”,“2.4”,”“
    11,“1675755”,“10”,“CRIMP HOUSING, 2.54MM, 3WAY”,“MULTICOMP - MC34483”,“YES
    ”,“0.083”,“In Stock”,“0.83”,”“
    12,“1675756”,“10”,“CRIMP HOUSING, 2.54MM, 4WAY”,“MULTICOMP - MC34485”,“YES
    ”,“0.122”,“In Stock”,“1.22”,””
Got to restock my connector box… should be pretty much dead on £30 inc vatOn 22 September 2012 17:00, Ben Dooks bjdooks@googlemail.com wrote:
Bloody hell Bob!
We really need to write some software to make this easier! While we
are on the subject I reckon we should write something to make pledging
and paying for pledging easier…
    5,“1516264”,“10”,“CONNECTOR HOUSING, 2WAY”,"JST (JAPAN SOLDERLESS TERMINALS)
  • XHP-2","YES “,“0.035”,“In Stock”,“0.35”,”"
    6,“1516265”,“20”,“CONNECTOR HOUSING, 3WAY”,"JST (JAPAN SOLDERLESS TERMINALS)
  • XHP-3","YES “,“0.045”,“In Stock”,“0.9”,”"
    7,“1516266”,“20”,“CONNECTOR HOUSING, 4WAY”,"JST (JAPAN SOLDERLESS TERMINALS)
  • XHP-4","YES “,“0.063”,“In Stock”,“1.26”,”“
Add everything you want to a basket, go into the basket, click export as
CSV. Paste the CSV into the thread.
Theres a button Ben can press in his basket to paste in the CSV and
automatically add it to his basket.
This has a handy side effect of giving you your price including VAT for
your bits :slight_smile:
Easy!On 25 September 2012 13:16, Alexander Lang alexanderlang1980@gmail.comwrote:
Bloody hell Bob!
No.”,“RoHS”,“Unit
TERMINALS)
    TERMINALS)
    TERMINALS)
    TERMINALS)
    TERMINALS)
    TERMINALS)
    233-508.”,“YES
    MC34483”,“YES
    MC34485”,“YES
vat
Bloody hell Bob!
Already have plans for this…
Kimball
ok, ordered.
Delivery should be tomorrow.On Sep 25, 2012 1:34 PM, “Ben Dooks” bjdooks@googlemail.com wrote:
ok, ordered.
– Ben Dooks, http://www.fluff.org/ben/ bjdooks@googlemail.com
