Farnell order
I am considering a farnell order before next HACMan meeting
so if anyone wants anything, then let me know by 1pm Tuesday.
Ben Dooks bjdooks@googlemail.com http://www.fluff.org/ben/
hi Ben,
please can you place this order for me. Thanks alot in advance.
1x 1296774 DURATOOL D00663 REPLACEMENT SOLDERING IRON
1x 1468824 NATIONAL SEMICONDUCTOR LM336Z-5.0/NOPB IC, SHUNT, VOLT REF, 5V
1x 172113 ROTH ELEKTRONIKRE 901 MULTIADAPTOR, EPOXIED FR4, SOT-23
1x 1843663 ANALOG DEVICES ADR3433ARJZ IC, VOLT REF, 3.3V, 6SOT23On 9 February 2012 12:14, Ben Dooks bjdooks@googlemail.com wrote:
Steve,
A quick question…why are you using a five volt shunt regulator??
AlexOn Feb 9, 2012 3:49 PM, “Steven Choi” swchoi.choi@gmail.com wrote:
hi Ben,
Steve
By the way I think you got one of your part numbers wrong:
1172113 for the SMD converter PCB and not 172113 which come out as
N-type coax connectors.
Only trying to help…
Regards
P.S. Nothing wrong with using a 5V shunt reg it just seems a little
overzealous…still its only 58p so it doesn’t really matter.On 9 February 2012 15:58, Alexander Lang alexanderlang1980@googlemail.com wrote:
Steve,
hi Ben,
hi Ben,
Item “not found” according to Farnell. Can you check this please.
Thanks alot for your help Alex !!! You’re the man!! Ben I don’t
require 1172113. I assumed it’ll be to 0.1inch headers.On 9 February 2012 16:16, Ben Dooks bjdooks@googlemail.com wrote:
On 02/09/2012 03:49 PM, Steven Choi wrote:
hi Ben,
Just a few things this time!
2x
http://uk.farnell.com/isocom/isq1x/optocoupler-dip-16-quad-tr-o-p/dp/1683215
1x
http://uk.farnell.com/wuerth-elektronik/61400416021/receptacle-usb-type-a-pcb/dp/1642033?Ntt=1642033
10x
http://uk.farnell.com/multicomp/mcgpr10v108m8x14/capacitor-1000uf-10v/dp/1902885
1x
http://uk.farnell.com/samtec/ces-129-01-t-s/receptacle-2-54mm-single-29way/dp/1667533
Ta
To unsubscribe from this group, send email to hacman+unsubscribe@**
googlegroups.com hacman%2Bunsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/**
group/hacman?hl=en-GB http://groups.google.com/group/hacman?hl=en-GB.
and 2x
http://uk.farnell.com/stmicroelectronics/tip115/darlington-transistor-to-220/dp/9803980On 14 February 2012 12:28, Bob Clough parag0n@ivixor.net wrote:
2x
1x
10x
1x
Ta
and
1x
http://uk.farnell.com/te-connectivity-amp/1-84984-2/connector-ffc-fpc-1-0mm-12way/dp/1816428
1x
http://uk.farnell.com/molex/52207-1260/connector-fpc-1-0mm-12way/dp/1757080On 14 February 2012 12:40, Bob Clough parag0n@ivixor.net wrote:
and 2x
2x
1x
10x
1x
Ta
along with
1x
http://uk.farnell.com/duratool/d00663/replacement-soldering-iron/dp/1296774
(going
to try and change the connector to hook it up to the solder station!)On 14 February 2012 12:44, Bob Clough parag0n@ivixor.net wrote:
and
1x
1x
and 2x
2x
1x
10x
1x
Ta
The order is incoming, so hopefully all here for tomorrow.
