Hackspace Manchester will reopen on Wednesday 2nd December from 00:01, we will be operating at Alert Level 4
What does Alert Level 4 Mean
Alert level 4 will mean that the space can only be accessed by one household at a time (so normally one member but if there is more than 1 member from a household they can use the space at the time being) this rule applies to support bubbles too if your in a single household and you have formed a support bubble with a member from another single household you may use the space together however the member that has booked the space will be the only one who can access the space directly using their tag
During Alert Level 4 we will not be able to carry out inductions
So how do you access the space?
Visit www.hacman.org.uk/space-booking and select the timeslot you want to access the space. These are bookable in 1 hour slots and you can book more than one slot each day.
You will need to be logged in to make the booking using your member system username and password
You can also cancel or reschedule existing bookings from this page by scrolling to the bottom.
How long will this last
The Greater Manchester Restrictions are set to be reviewed on the 16th of December should we move back to tier 2 then we will move the space back to level 3 which provides for general access to the space and equipment booking.
To be clear the space won’t be closing, access will just be restricted to one household/support bubble at any time and you will need to book using the website to get access
Should you have any questions please email the board
