Handheld AC->DC power supply 60W
We are business in Warrington and will soon launch a new product : handheld DC power supply.
a handheld switch mode AC to DC power supply which is ideal for those
needing power supply with limited space or on the move (for field jobs).
This unit is believed to be the first NC handheld power supply.
Let me know if interested.
Rgds
Marvin
I have a use for a conveniently portable power supply, but I’m confused by your announcement.
What is NC ? Numerically controlled ?
What does handheld mean ? Like a battery for phone charging ?
Since it’s AC, how is it different from a small laptop power supply like the HP travel adapter ?
Hi Adrian, i tried to attach a photo here but it did not allow me ?
below is the introduction, hope this helps?
UNIALL MOP60H Portable Handheld Power Supply
Resembling a Digital Multimeter, this unit is a great size for those needing power on the move or with limited space for bench power supply.
The compact design means that you can easily add this to your tool box, giving you access to variable DC output from any wall socket.
Please note that this is not a battery operated device - it does require mains power using the supplied mains lead.
Features:
• 60W Output Total
• Dual USB ports - 5V @ 2A
• Input voltage 90V-255V 50/60HZ
• short circuit protected
• Handy fold out stand
• 3.2 inch Full colour IPS HD LCD display screen 480x320 pixels
• Graphic display
• Output status indicating (CC and CV)
• 3 Preset Memorised USE settings
• Dimensions: 21x10x4cm Weight: 590g
We will also lauch 2 more models with 1-60V / 0-5A and 2-60V/0-10A
Specification
Input Voltage 90V-255V 50/60HZ Remarks
Output Voltage 1-30V
Output Current 0-3A
Working Temperature -10 to 40 celsius degrees
Load Regulation
<200mv
Line regulation Voltage <0.01%+5mV
Line regulation Current <0.01%+5mA
Ripple and Noise 10mVRms
Setting Value Accuracy
Voltage 10mV
Current 1mA
Display Accuracy
Voltage ±1%+3digits
Current ±2%+3digits
Setting Accuracy
Voltage ±1%+3digits
Current ±2%+3digits
Temperature Drift Voltage 200ppm
Tracing error < 2 digits
Interesting!
The specifications look good. Is there a website showing the product? Final question - How much?
hi Alex,
image pls see below link
https://uniall.uk/powersupply/nsmail-4.jpg
price not finalised yet as the final product will be launched in about 2 months,
but will be under £200.
What is NC ? Numerically controlled ? - yes
What does handheld mean ? Like a battery for phone charging ? - it means it is a very portable one like a multimeter.
Since it’s AC, how is it different from a small laptop power supply like the HP travel adapter ? - the difference is you have the freedom to set whatever settings of voltage and current within the rating, it is ideal for testing and repairing jobs. also the usb ports is good for charing phones etc.
