This thread will be used by laser maintainers to log any work done to ‘Bluey’ the larger blue laser cutter, it will be a record of works needed for commissioning and ongoing maintenance.
Machine Info
- Dimensions (approx): 1450x575x940 (w/h/d)
- Controller: Ruida RDC6445G(EC)
- MAC address: 02:A0:C9:78:3E:FD
- IP: 172.16.0.253
Commissioning DONE
- Buy Lightburn
- Lightburn installed (persistently) on VA Mac
- Find Manual
- Temporarily hooked up @thinkl33t 's chiller
- Test fired laser
- Get Lightburn Discount for members
- CW-5000 chiller purchased and collected
Commissioning Todo
- Add Lid Interlock (micro switches now acquired)
- Replace Cam Locks
- Add Keyswitch inline with laser fire line
- Make / commission base unit with materials storage
- ‘Not a touchscreen’ reminder
- Firmware upgrade research
- Extraction
- Automate air-assist with relay
- Create training toolkit
Created a seperate thread to try and log the details needed for the setup of the plywood base
Update on Commissioning todo list
Replace Cam Locks
Extraction
Yesterday I:
- Set the autofocus for 3mm material in firmare, this seemed to bring the head closer to the material and produced a better cut. (although personally I think it’s still too far).
- Realised not to set focus to yes in the firmware settings, this made the laser cutter lower the bed to a point past the thread limits
Firmware was upgraded as part of the automatic air assist commissioning
Things to do on Bluey:
- Need to put base on casters to allow laser alignment
- Fix guiding laser (the wire connecting to power has snapped)
- Print sign for cost of laser time and materials
- Cleaning lens using lens cleaning wipes
- Put slow closing arms on lid
- Change laser switch for a key based version to lock out
- Make box for laser maintence tools (to fit behind laser cutter)
- Create material test but mount it so it doesn’t get chucked
- Update material list in lightburn
- Wire to extractor fan should be reinforced
- Printed QR code or short url to link to induction sign up page
