Laser Cutter / Wiki
Back in October I managed to sneak my way onto the Laser Indcution course
(one person was a no show, and I was just around at the time)
I took a lot of notes and wrote them into my own wiki (since I figured I’d
forget almost everything I picked up)
I’ve recently copied and pasted the info from my own personal wiki
(dokuwiki), into the hacspace wiki
I’ve made sure not to overwrite any of the original pages on there
since I’ve only used the cutter once, some of this info may need to be
reviewed / may be inaccurate
http://wiki.hacman.org.uk/Laser_Cutter/Overview - root overview
http://wiki.hacman.org.uk/Laser_Cutter/Software
http://wiki.hacman.org.uk/Laser_Cutter/Design
http://wiki.hacman.org.uk/Laser_Cutter/Cutting
http://wiki.hacman.org.uk/Laser_Cutter/Materials
Since I’m using dokuwiki locally, I was also able to export the pages
automatically into a pdf document (see attached)
I also slapped the logo in just for the hell of it
I just figured some of this might be of use for reference or other
inductions maybe
although as before this could probably do with being reviewed by someone
with more experience using the laser
laser_cutter.pdf (141 KB)
Richard,
You’re a star. We’ll have a check and update as necessary.
For other people’s information this does not mean you can use the laser cutter without receiving an induction.
Best,
tamarisk kay
e: tamarisk@tamarisk.it
p: 07949 151 100> On 4 Feb 2015, at 16:31, garlicbread (Richard) garlicbready@googlemail.com wrote:
I took a lot of notes and wrote them into my own wiki (since I figured I’d forget almost everything I picked up)
I’ve recently copied and pasted the info from my own personal wiki (dokuwiki), into the hacspace wiki
since I’ve only used the cutter once, some of this info may need to be reviewed / may be inaccurate
Since I’m using dokuwiki locally, I was also able to export the pages automatically into a pdf document (see attached)
I just figured some of this might be of use for reference or other inductions maybe
although as before this could probably do with being reviewed by someone with more experience using the laser
<laser_cutter.pdf>
