I was just about to suggest this got looked at as part of hack the space day but doing it sooner would be awesome.
What time are you planning on doing it? Would you mind if I popped along while you’re doing it so I could maybe learn a little more about how it works? At the very least I could hold things for you or make a brew.
I, and several others, have used the laser without issue since this was
posted. I wont deny it needs a clean but none of us could replicate the
skipped Y axis steps…
T.On Thursday, 6 November 2014 10:33:05 UTC, bob wrote:
The laser cutter is misbehaving at the moment, skipping steps on the Y
axis, and slightly low on power towards the right hand of the bed.
I’m looking at doing a full maintenance run-down on it this weekend, so
I’d suggest people don’t use it till then.
i had the problem that the x axis seems to be too short at the extremes.
like when cutting up to 28 cm sheets there’s is like 1 mm of difference in
the cuts.
T.
We have now managed to replicate the issues and are working on this.
T.
tamarisk kay
tel: 07949151100
email: tamarisk.kay@gmail.comOn 9 November 2014 11:37, Constantin Popp constantin.popp@gmail.com wrote:
hi tas and others
the cuts.
T.
