I would like to get some training on the lathe please.
Answers to your questions:
How much experience you have using a lathe
Sadly not anyā¦Itās always been something I have seen others do.
What you would like to do - this can be techniques or general
descriptions of projects
Iām not sure yetā¦hopefully inspiration will strike. A turners cube
perhapsā¦Or a Piccolo or tin Whistle!
Any questions you have about the lathe, its capabilities, and
limitations
What is the maximum material size the chuck can hold? Is it possible to
cut threads easily? Does our lathe still run backwards?
None - never operated one before. However, have done a lot of other general metalwork, and have been watching lathe videos on youtube for a while.
Just play around and learn to use the machine, initially. I was thinking of maybe making a chess set as a practice project.
Not really - I saw the machine in person yesterday so I think I have a general idea of its range in terms of work sizes. Iām happy to just find out whatās what as we go.
Iāve used the one in the space a bit, and watched quite a lot of youtube videos on it, but not a lot of hands on experience
What you would like to do - this can be techniques or general descriptions of projects
Nothing in mind at the moment, although I may have one or two things to use if for in the future
Any questions you have about the lathe, its capabilities, and limitations.
I was wondering about cutting threads, but I suspect that might not be possible currently, because the gears are imperial instead of metric. I donāt think thereās a quick change gear box on the one we have, although I did spot possibly a change of one gear to another via a couple of leavers.
Experience: I was shown how to use it when it was first donated, and have turned quite a few pieces on it.
Iād like to learn more about indicating and alignment of the lathe parts (iāve largely been going with āthis feels rightā, and more information on workholding. Iād also like to know how to use it in horizontal milling mode, and how to properly use the knurling attachment
Hi Greg - very interested in getting trained up here.
Experience - zero hands-on experience, just a lot of watching YouTube videos.
Projects - probably a few decorative items and/or components, at least to start with. At some point Iām sure Iāll want to do a saber hilt.
Questions
The wiki page for the lathe has a warning that itās āfor metalwork onlyā - is that a policy? Iām more likely to want to turn wood or plastics than metal, though I may step up to alu or brass at some point.
Am I right in thinking itās a machine lathe (i.e. can drive the carriage), or is it manual feed only?
Does the lathe fall under the lone working policy?
Woodās a no go for the metal lathe unfortunately, itās because it has a tendency to mix with the oil and be quite abrasive.
Metal and plastics (not sure if itās all plastics or just certain ones, Greg should know) should be okay.
@Riot - as I understand it some of the more dangerous tools have a ānot to be used if youāre alone in the spaceā policy attached. Not entirely sure of that though,or which tools, but given that Iāve heard lathes described as āthe single tool in the shop that most wants to kill youā it seemed a safe bet.
I think we need a āthis is bloody dangerousā label on the lathe because they can be dangerous
For example
leaving the chuck key in by accident and having it propel itself across the room when switching it on
having it run forward in one speed, then switching it into reverse suddenly can cause the head to unscrew itself / drop off and skate across the floor (one of my fatherās stories)
having loose hair or clothes wrap around spinning parts (lots of horror stories on youtube)
From what I understand there are plans afoot to make it safer with estops etc though
Thanks to everyone who replied - I have answered some of the questions below
Taper turning is possible, however making a flat would be harder
According to the manual the largest part the machine can accommodate is 7 inches in diameter and 20 inches long.
There are 2 ways of making threads - standard threads can be made with taps or dies as appropriate - there is a die holder and taps can be held in the tailstock chuck. Specialist threads can be cut using a special cutting tool - these can be metric or imperial.
The lathe should only be used with metals and plastics (Acetal, acrylic, nylon, PTFE, etc.) Wood should not be turned on the metal lathe - if someone wants to start a pledge for a wood lathe, please do.
The carriage can be driven under power, but the cross slide is not equipped with power feed.
The lathe is covered by the lone working policy, and will be outfitted with an appropriate label before training commences.
The lathe has been rewired so that the labels on the switch correspond to the rotation of the chuck.
I expect training to commence shortly - please await an announcement here and on telegram.
I do have a metal lathe in bits in the small garage that could be used for turning wood if you want.
Thereās a good chance itāll be thrown out unless it finds a home (although at the moment it seems to be safe / not going anywhere)
The main problem is finding the room to put it some place.
