lm317?
Do we have some lm317 at the lab? The one I pulled out of my bits bin
appears to have seen better days. I don’t think it’s regulating at all.
Instead of 10v I get 18 lol
Have you got the voltage selector pin set properly? If I remember rightly
its 1.25v at 20ma or so. Double check your calculations and resistors.
Alex can probably elaborate a bit more…On 24 Oct 2013 22:06, “Steven Choi” swchoi.choi@gmail.com wrote:
Steve
Need to see your circuit to help. Tom is correct though. Say Input voltage
is 20V. Reference pin will be as Tom said at 1.25V. Output should be at the
voltage division you set down to 1.25 min. Is lm317 hot? If 18V output
input must be at that value or more. Check for shorts etc.
We do have some at the space if you need one.
I can only.assume its dead.because.the website I.used to check the resistors applies for lm317 as well as lm338 . I used a known working lm338 and it works. I get 10v. also if u mean the adjustment pin it was putting out 18v I believe. if I understood correctly it should always have 1.25v that is why u.can’t get true zero volts output without some.extra circuitry. I will double check perhaps I wasn’t measuring with respect to gnd.
unless am being.a tool againAlexander Lang alexanderlang1980@gmail.com wrote:
Steve
Lm338 is the same as an lm317, just it can give out more current and a
higher input…if it worked keep using it.
gnd.
Steve
the
rightly
an
an
