There is a wishilist located over here you could add to
http://wiki.hacman.org.uk/Tools_Wishlist
One of the things I’m working on as a home project (once it arrives) is a
ooznest cnc ox which is a large area cnc.
It uses v-slot which means it’s very easy to swap or add custom heads using
T Nuts and M5 screws.
It’s also a lot cheaper and has a larger area (metal frame plus motors,
minus electronics or heads equals £650 for 500mm x 750mm)
What I’d like to see is one of these located in the space (once we have the
room for it in version 3 of the hacspace next year)
But just not for cncing but for also all of the things you’ve mentioned
below such as solder paste pick and place etc.
Ideas I’ve come up with so far include
PHR803-T dvdrw head for exposing UV sensitive PCB’s
EDM metal machining
https://www.youtube.com/watch?v=EeKreZqgi9M
machining out a Bulldog extruder for 3d printing
http://www.thingiverse.com/thing:215457
solder paste dispenser
http://www.thingiverse.com/thing:384680
multi coloured ring light / bracket for a usb microsope / camera
holder for a small spray paint gun
There’s no pre-written software for special heads of course, but figuring
that out is part of the fun :)On Sunday, November 1, 2015 at 3:10:37 PM UTC, rich op wrote:
All valid points, I was mainly excited about the solder-paste dispensing,
pick and place assembly and automated soldering.
I think the size could be beneficial, easy to store and move. You guys are
right, it may do tasks in a lighter-weight league compared to it’s
individual counterparts.
I think it works out in the cost/benefit analysis, due the amount of tasks
this thing can double as, and if we split it the cost between a group and
say chuck £90, wait a year, hardly any risk if it doesn’t get funded and
could be surprisingly beneficial to have a futuristic robot hand helping
out.
I’m not sure I’m getting the point across so here’s ROBOT ARMS in capital
letters.
On 1 November 2015 at 09:13, Alexander Lang <alexande...@gmail.com <javascript:>> wrote:
I’m afraid I’m not on board either. I’m with Richard (garlicbread). It
doesn’t look like it has the chops to be useful - it’s a nice idea but it
doesn’t look rigid enough.
On Sun, 1 Nov 2015 1:34 am garlicbread (Richard) < garlic...@googlemail.com <javascript:>> wrote:
I suspect it’s a bit too small for what it is
For 3D printing it looks as if it’s main limitation might be speed
compared to a conventional carteasen bot
so it’d work but I think you’d end up with a long wait for extrusion
prints looking at the vids
From a cncing poit of view it’s only going to be rigid enough for light
engraving, or cutting at a slow speed
looking at the vid they’re only removing 0.2mm on each pass so it’s
going to be slow without a big bulky frame or large beefy motors
It can be used for milling and drilling pcb’s but we already have the
proxon and the roland cnc I think Jim is working on
which should be able to mill deeper and faster I’m guessing, plus
there’s the laser
This leaves pick and place, foam wax cutter, screw driver, soldering
head, resin printer (needs a seperate dlp projector)
and the fact the software may be a bit more integrated / polished,
although bearing in mind it is a kick starter.
(also does the $1399 include 20% vat?)
Richard
On Saturday, October 31, 2015 at 9:18:16 PM UTC, rich op wrote:
Hi guys,
I’ve seen this kickstarter for a seemingly next level instrument called
the MakerArm:
https://www.kickstarter.com/projects/1849283018/makerarm-the-first-robotic-arm-that-makes-anything
https://www.google.com/url?q=https%3A%2F%2Fwww.kickstarter.com%2Fprojects%2F1849283018%2Fmakerarm-the-first-robotic-arm-that-makes-anything&sa=D&sntz=1&usg=AFQjCNH1lE0E1W70A3OubsrFOGHd0QA1cA
I think would be amazing to have in the space, most funding tiers have
been taken already, and the cheapest one left is at $1399 around £900, is
there ten of us that want to put in £90 each? Normal retail price would be
double that amount.
Ten days to go and they look on target to get the 350k with the current
amount at 299k.
Is anyone interested in joining in for a group buy on this?
an email to hacman+un...@googlegroups.com <javascript:>.
<javascript:>.
https://groups.google.com/d/topic/hacman/vaTwBhCQpnM/unsubscribe.
<javascript:>.
