I’m attending the barcamp hosted by Manchester girl geeks. In addition I’ve
been contacted and asked if we would run a stand.
I’m going to run the stand but would like assistance and items to show off.
Its on the 31st of may with more details here
http://manchester.girlgeekdinners.com/2014/03/23/girl-geeks-event-barcamp-2014/
Cheers Kat
I may have one or two bits finished by then and around to help.
Best ask nearer the time in case I get a free unscheduled holiday again.On 8 April 2014 11:40, Kathryn Reeve kathryn@binarykitten.com wrote:
I’ve been contacted and asked if we would run a stand.
Cheers Kat
Kat…my mini infinity mirror and knock clock are on top of my blue box.
You could take those although the time is incorrectly set on the clock. It
can be fairly quickly set if you have access to an arduino and breadboard.
You will need to open the knock clock box…the top is removable and then
remove the RTC module and then place it in the breadboard - its on header
pins. Use the adafruit tutorial to set the time on the module. Then put it
back in the knock clock. It will immediatly work once powered.
The mini infinity mirror works, but needs a usb power supply connected to
the minimus.
Good luck
Good luck
off.
Cheers Kat
