If you were doing a project that required a microcontroller would you
consider using a PIC or Arduino/AVR? Perhaps something else? If you
wouldn’t use a PIC normally then what situation would make you use a PIC?
Thanks in advance,
Mike.
FSF member #9429
http://www.fsf.org/register_form?referrer=9429
http://www.fsf.org/about
"The Free Software Foundation (FSF) is a nonprofit with a worldwide
mission to promote computer user freedom and to defend the rights of all
free software users."
For me it an AVR would be the default choice. I started using PICs in
the early 2000s with MPLAB, but when AVRs came along with avr-gcc and
programming tools that worked under Linux I switched to those. The PIC
situation might have improved since then, but I haven’t found any
reason to go back to them yet.On 26 October 2015 at 20:58, Michael Dorrington michael.dorrington@member.fsf.org wrote:
Thanks in advance,
Mike.
FSF member #9429
I’d choose the microcontroller that best suited the project (in my
opinion). That is normally arrived at by setting some design criterion and
then working things out.
The criterion usually is made up of the following:
Time - How much time will this take if I use a microcontroller I’m familiar
with over one I’d have to learn…
Cost - What is the overall budget and can I justify spending more money on
a known microcontroller over something cheaper
Functionality - Does the microcontroller have the functionality required or
will I need to add extra circuitry to achieve the required result.
Ease of use and assistance - How hard is it to develop with the
microcontroller and is there a large community associated with it that can
provide assistance when needed.
To be frank, there is no single correct microcontroller for every project
and like there is no single tool that’s perfect for every job. Pic and
arduino microcontrollers have their strengths and weaknesses just like
everything else. Choosing which micro to use comes down to the skill of the
engineer when assessing the requirements of the project.
AlexOn Mon, 26 Oct 2015 8:58 pm Michael Dorrington < michael.dorrington@member.fsf.org> wrote:
Thanks in advance,
Mike.
FSF member #9429
Pics have improved considerably and often have slightly better electrical
characteristics over avrs but the community behind avrs is huge and because
of that and a lack of free compilers and open source stuff in the beginning
avrs have slightly got the edge…both are good though and it depends on
what you are trying to achieve that should drive the decision…
AlexOn Mon, 26 Oct 2015 9:49 pm Alexander Lang alexanderlang1980@gmail.com wrote:
familiar with over one I’d have to learn…
or will I need to add extra circuitry to achieve the required result.
Thanks in advance,
Mike.
FSF member #9429
You forgot Cortex-Mx ARM devices.
I would put the answer into several parts:
Firstly, there are now PIC devices that are easier to interface to USB.
They have inbuilt oscillator, so you need about three caps to make them
work (I have built a veroboard PIC16F1459 which happily talks to a USB
connector). So the first criteria is which peripherals do you want/ease of
construction.
The software state is that the PIC still really need the MPLab IDE (which
does work under Linux) but it isn’t something I really like. The AVR gcc
port installs nicely and avr-gcc seems to work out of the box so you can
just write makefiles if you need.On 26 October 2015 at 20:58, Michael Dorrington < michael.dorrington@member.fsf.org> wrote:
Thanks in advance,
Mike.
FSF member #9429
Humph,
I thought my first email was nice and generic. I wasn’t going to mention
specifics until Jim did and then I felt compelled to!
Arm Cortex MX devices are also coming along nicely particularly with the
mbed stuff. However I stand by my statement of it depends on what the
designer wants to achieve etc etc
AlexOn Tue, 27 Oct 2015 5:49 pm ‘Ben Dooks’ via Hackspace Manchester < hacman@googlegroups.com> wrote:
construction.
Thanks in advance,
Mike.
FSF member #9429
Any idea what the current status of the open source mbed toolchain is?
Or do you still have to use that online IDE?
It can be used offline now…absolute ball ache to get working though.On 27 October 2015 at 18:29, Alan Burlison alan.burlison@gmail.com wrote:
Any idea what the current status of the open source mbed toolchain is? Or
Shame, because the board itself is quite nice.
The Cortex M3 is awesome and coupled with build in USB and ethernet and
CANbus etc makes the Mbed LPC1768 one of the best development boards
about. Definitely a shame not being able to easily use it offline.On 27 October 2015 at 19:52, Alan Burlison alan.burlison@gmail.com wrote:
You can program it directly, its just an ARM, mbed is just to make it easier
Agreed but it’s the mbed libraries which make it usefulOn 27 October 2015 at 19:55, Kimball Johnson kimball@bowerham.net wrote:
easier
https://developer.mbed.org/handbook/Exporting-to-offline-toolchainsOn 27 October 2015 at 19:56, Alexander Lang alexanderlang1980@gmail.com wrote:
easier
