I’ve been pointed at the following circuit for amplifying the output of
an electret mic and smoothing it before feeding it into an A2D to get an
indication of sound level - integrating the electret output for
somewhere between 10-500ms is probably about right. The electret will be
biased with 5V and then through a cap before being fed into this
circuit, as normal.
Question: How do I calculate the values of R1 & C1?
I’m aware this could be done with op-amps but I don’t need audio
quality, just a smoothed indication of volume and size/part count is
more important.
Grumble…I am not a plumber!
I will respond presently
AlexOn 15 May 2014 14:39, “Alan Burlison” alan.burlison@gmail.com wrote:
I’ve been pointed at the following circuit for amplifying the output of an
indication of sound level - integrating the electret output for somewhere
between 10-500ms is probably about right. The electret will be biased with
5V and then through a cap before being fed into this circuit, as normal.
I’m aware this could be done with op-amps but I don’t need audio quality,
just a smoothed indication of volume and size/part count is more important.
I know, but I also knew the subject line was guaranteed to get you to
read the email
Thanks, it’s appreciated
