Open Access Control for Hacker Spaces v1.0
I know we have an access control system in the pipes… would it be worth
someone who knows about it putting in there tuppence-worth on the
Hackerspaces Mailing list?
Jon---------- Forwarded message ----------
Date: 9 Apr 2010 20:58
Subject: [hackerspaces] Open Access Control for Hacker Spaces v1.0
To: “Hackerspaces General Discussion List” discuss@lists.hackerspaces.org
We’ve got a preliminary hardware design together finally, along with
the code. Check out the schematic and download links for everything
at:
This system uses the Arduino Duemilanova board and so far has been
breadboard tested to support:
-DS1307 Real-time clock with battery backup
-(2) Wiegand26 reader inputs (optoisolated)
-(4) Alarm zone monitor ports using Analog0…3 (optoisolated)
-(4) Relay outputs, rated to 10A/220VAC
-Spare pins 10…13 to enable Ethernet shield use
-Built in 12V unregulated, 5V regulated, 12V regulated supplies for
alarm sensors, door hardware
-Built in UPS (smart charger in next design)
-Separate fuse protection for everything
So this will basically allow 2 separate Wiegand26 door readers, 4
independent relay outputs for unlocking doors or alarm sirens, 4
inputs for alarm/other sensors, easy upgrade to Ethernet logging.
(It’s currently doing Syslog format via USB serial.) It has a built-in
UPS backup, much like a commercial alarm system and it allows multiple
power buses for motion detectors, fire sensors, etc that are separate
form the logic bus. I also put an EMF kick-back diode in for the door
hardware bus (unregulated 12V).
I would appreciate any feedback in terms of:
  1. What additional features would be nice?
  2. Any obvious design flaws.
Thanks!
John
Discuss mailing list
Discuss@lists.hackerspaces.org
http://lists.hackerspaces.org/mailman/listinfo/discuss
