OSHCamp 2019 (31/08 + 01/09) programme and Wuthering Bytes.
Hello,
The programme has now been announced for Open Source Hardware Camp 2019, with a
total 12 talks and 6 workshops confirmed. Topics including customising a RISC-V
core, building an FPGA network-on-chip for a Raspberry Pi Zero cluster, open
source test & measurement, gearing up for volume manufacture, next generation
open source FPGAs, SMD soldering, EMC design for open source hardware, and more!
Thanks to the generous support of RC2014, all delegates will also receive an
RC2014 Micro Z80 SBC kit upon registration on the Saturday.
As in previous years, there will be a social event on the Saturday evening and
OSHCamp returns to Hebden Bridge in 2019 and once again will be hosted to
coincide with the Wuthering Bytes technology festival.
We have some fantastic talks lined up for Festival Day, including a keynote from
JP Rangaswami plus talks on using anti-matter emitters to map the human body,
the incredible story of the Lyons Electronic Office that put Britain at the
forefront of business computing in the 1950s, amateur nano and pico-satellites,
and an introduction to Tesla coils — with live demo! — to name but a few.
You’re encouraged to check the website for details of other participating
events, as some of these are likely to be of interest. In particular a
free-to-attend workshop on Mon 2nd Sept, “From Hello World to professional IoT
applications with Zerynth”, where attendees will each leave with a free PSOC 6
based microcontroller development kit worth around £120.
Andrew
On the 31st August 2019 at Hebden Bridge Town Hall, St. George’s Street, Hebden
Bridge, HX7 7BY, UK.
Open Source Hardware Camp 2019 will take place place in the Pennine town of
Hebden Bridge, where it will return to be hosted for the sixth year as part of
Hebden Bridge is approximately 1 hour by rail from Leeds and Manchester. Budget
accommodation is available at the Hebden Bridge Hostel which adjoins the venue,
with private rooms available and discounts for group bookings.
There will be a social event on the Saturday evening from 8PM.
*** Saturday :: Talks ***
— Customising a RISC-V Core
This talk walks through the RISC-V ISA and the microarchitecture of an
open-source RISC-V core, to provide an understanding of how new instructions can
be added to the hardware.
RISC-V is an open Instruction Set Architecture (ISA) that can be implemented
freely. The ISA is modular, providing a base set of integer instructions
alongside standard extensions for multiplication, floating point, atomic
operations, and many other categories. In addition to standard extensions, the
ISA reserves space for user-defined extensions, providing the flexibility to add
custom instructions that fulfil any purpose.
There are many open-source implementations of RISC-V cores - in this talk we
will look at a small core written in SystemVerilog that is simple enough to be
understood by those relatively new digital logic design. We will walk through
the different components of the core and how they fit together to build a
picture of how instructions are decoded and executed, and go through an example
of the changes to each component needed to support a custom instruction.
  • Dr Graham Markall is a software toolchain engineer at Embecosm, which provides
    open source toolchain services. Most of his work focuses on GNU toolchains (GCC,
    Binutils, GDB, etc.) and the use of cycle-accurate simulation for pre-silicon
    toolchain development and testing. His current projects focus on the development
    of customised toolchains for various RISC-V systems, ranging from small,
    deeply-embedded applications up to high-performance multicore systems.
— Building A Network on a Chip for a Raspberry Pi Zero Cluster
A Raspberry Pi cluster is a popular platform for experimentation and learning
about parallel computing. The tiny Raspberry Pi Zero has no built-in ethernet
capability, so a Pi Zero cluster needs an alternative way to connect the CPUs.
By implementing a specialised local network on an FPGA chip, linked to a serial
or SPI port on each CPU, we can avoid the need for bulky ethernet cables and
switches, and build a very compact cluster with low cost and low power
consumption.
  • As a member of Oxford University’s Programming Research Group in the 1980s,
    Richard Miller wrote software for parallel computing systems from the transputer
    to the Cray T3D. More recently as a freelance software engineer, he ported the
    Plan 9 operating system to the Raspberry Pi. His current focus is on FPGA
    circuit design.
— From humble beginnings to manufacturing the HILTOP open source test and
measurement platform and the problems along the way!
The story of how three entrepreneurs with a vision and willingness to succeed
have carved out an open source test and measurement business and the details
behind the hardware and software problems they had with early prototypes and
product integration.
  • Tim Telford is a hardware engineer with diverse skill set and highly motivated
    self starter. Passionate about design detail and experienced in high reliability
    solutions for the Aerospace, Defence, Telecoms and Nuclear industries.
Development of test equipment and measurement systems for Rolls-Royce Aerospace.
Systems and Electronic engineering experience within the nuclear industry.
Design of commercial test equipment and high integrity, high value projects.
Analogue and Digital board level design, Schematics, PCB, FPGA development, DFM,
DFT, Simulation, systems design and integration/testing. Requirements
management, FMEA, WCA & PSA analysis techniques.
  • Joe Burmeister spent nearly 12 years in the console and PC game industry. He
    worked in a number of areas from graphics and animation engine to art and
    animation tools, finally file systems and databases.
Joe comes from a multiple platform background, partly as consoles used to not be
PCs, but also having grown up on RISC OS (Acorn’s desktop ARM OS), before moving
to Windows for work then Linux for fun and finally work. For the past five years
Joe has done work on GNU/Linux, often on ARM.
Having started out bedroom programming, Joe is a strong believer that everyone
should have the option of source code and learning how things work.
— Linux on Open Source Hardware and Libre Silicon
This talk will explore Open Source Hardware projects relevant to Linux,
including boards like BeagleBone, Olimex OLinuXino, Giant board and more.
Looking at the benefits and challenges of designing Open Source Hardware for a
Linux system, along with BeagleBoard.org’s experience of working with community,
manufacturers, and distributors to create an Open Source Hardware platform. In
closing also looking at the future, Libre Silicon like RISC-V designs, and where
this might take Linux.
  • Drew Fustini is an Open Source Hardware designer at OSH Park, board member of
    the BeagleBoard Foundation, maintainer of the Adafruit BeagleBone Python
    library, and Open Source Hardware Association vice president.
— Exploring the Gigatron TTL Computer
The Gigatron TTL computer is an open source computer constructed almost entirely
from TTL logic - without the need for a microprocessor. The unique design
combines 36 standard 74HCTxx TTL devices with ROM and RAM chips to make a
platform capable of colour VGA video and sound. The machine can host 1980’s
style games and can be programmed in interactive Tiny BASIC.
In the last year, Ken has explored the architecture of this machine and achieves
some performance gains by overclocking the cpu by over 200%. This has yielded a
platform that is rated at about 2 to 3 times the performance of the classic
1980’s machines, such as the C64, Spectrum etc.
Working with an unfamiliar architecture has meant creating some programming
tools and also simulating the machine behaviour on an ARM processor.
Ken discusses the progress to date - and poses the question, “What would
computers be like had the microprocessor not appeared when it did?”
  • Ken Boak began programming computers in 1979 at school, and has continued to
    do so - somewhat infrequently over the last 40 years. The Gigatron rekindles old
    memories of TTL logic and working with resource limited computing. It
    illustrates just how much can be done with such a minimal machine.
— Gearing up for Volume Manufacturing: Tales from China
The journey of a design from engineering sign-off all the way to customer
shipment takes many months of hard work and the smallest of hiccups could
translate to severe delays. With many actors involved, how does it all work?
What is involved in designing and shipping a consumer product with high volume
manufacturing in mind?
This talk will give the audience a behind the scenes look at what it takes to
ship electronics products at scale, particularly focusing on the approach,
dialogue and the processes required to run a successful manufacturing project.
  • Omer Kilic is an embedded systems engineer who works at the various
    intersections of hardware and software engineering practices, product
    development and manufacturing.
— Saving Your Electronic Conference Badge From A Life On The Shelf
As the creator of an electronic conference badge, you want to create something
memorable, a badge with Wow! factor which will be remembered fondly and remain
in use for years afterwards. Unfortunately so many badges end up sitting in
drawers gathering dust, never to see the light of day again. Firmware,hardware,
or documentation haven’t been kind to the conference attendees, and though
you’ve given them an amazing piece of hardware they just haven’t been able to
get a handle on it and use it in their own projects.
This talk gives a few ideas about how that might be avoided, how an awesome
badge can avoid being an ignominious piece of e-waste and become a valued piece
of hardware used in projects for years afterwards.
  • Jenny List is an electronic engineer and technical writer who spent a long
    career in electronic publishing from CD-ROMs to dictionaries before breaking out
    and forming her own hardware business, and writing about hardware as a
    contributing editor for Hackaday.com.
— What’s So Good About The Z80 CPU Anyway?
This talk will briefly cover the history of the Zilog Z80 CPU including early
development, some predictable places where it turned up, as well as some more
less expected uses. It will include a look at the architecture of the Z80 itself
and then an overview of how to build a simple Z80 based computer and program it
in BASIC. This will lead on to a description of the kit in your goodie bag and a
plug for the workshop on the Sunday.
  • Spencer Owen like many kids in the 80s, loved his ZX Spectrum and other 8 bit
    computers. This set him up for a career in IT, and he worked as a server
    engineer and network engineer for many years. In 2013, in a bid to see if he
    really understood how computers worked at the lowest level, Spencer went back to
    his roots built a simple Z80 based machine on a breadboard. This was to mature
    in to the RC2014, which Spencer started selling in his spare time in 2015.
    Within a few months it was clear that the RC2014 was taking up more time than he
    had spare, so he quit network job and started a retro computer kit company.
    Spencer is now the largest supplier of Z80 computers worldwide.
— Next Generation Open Source FPGAs
After the success of Icestorm and the growth of the open source FPGA ecosystem,
work started on the next generation of open source FPGA toolchains in 2018. This
includes the next-generation place-and-route tool nextpnr, designed to support a
wide range of FPGA architectures as well as producing higher quality results
with less runtime. Combined with Project Trellis which provides bitstream
documentation for the Lattice ECP5 FPGAs, a wide range of advanced projects such
as Linux-capable RISC-V SoCs with fast memory, Ethernet and video interfaces are
possible with an end-to-end open source flow.
This talk will introduce these new tools and their capabilities, as well as
discussing what lies ahead for open source FPGA tools, and how you can get
involved in this exciting new open world!
  • David Shah is a engineer at Symbiotic EDA and a Electronic and Information
    Engineering student at Imperial College London. He entered the world of open
    source FPGAs by extending Project Icestorm, the iCE40 bitstream documentation
    project, to include the newer iCE40 UltraPlus FPGAs. As well developing Project
    Trellis, he has been involved in the development of a new open source FPGA
    place-and-route tool, nextpnr.
— Heterogeneous design for embedded development
Developing embedded solutions for today’s challenging applications be them IoT,
consumer, automation or robotics requires a heterogeneous technology approach
involving hardware, FPGA, µC Firmware, and software combined at multiple levels.
Concepts such as Machine Vision/Learning, Artificial Intelligence coupled with
traditional embedded hardware and software stacks require hybrid approaches to
design and implementation. I take a look at typical hardware being used and
platform sweet spots I have been identified. I also take a look at some emerging
tools and approaches for tackling these heterogeneous projects.
  • Alan Wood has been working with parallel distributed programming for several
    decades. His recent work includes smart grids, 3D printers, robotics, automation
    and biotec diagnostics. His current research is focused on machine learning for
    embedded automation using FPGA and µC. He is a long term advocate of open source
    communities, a moderator (aka Folknology) for xCORE, the co-founder of myStorm
    open hardware FPGA community, as well as a co-founder of Surrey and Hampshire
    Makerspace.
— EMC Design for Open Source Hardware
Many Open Source electronics designs start off as cool development tools and end
up being integrated into commercial products due to their low barrier to entry
and ease of development.
Now your hardware becomes subject to various Regulatory requirements,
Electro-Magnetic Compatibility (EMC) amongst them. Whilst it might not be viable
for an Open Source project to undergo full compliance testing, there are things
that can be done to improve the EMC performance of your system.
In this talk, James gives an overview of common problems encountered during EMC
testing of Open Source hardware and the fixes required to resolve them. We’ll
also look at some key electromagnetic concepts (don’t worry, no scary maths)
that will help you look at your designs in a new light.
  • James Pawson runs Unit 3 Compliance, a West Yorkshire EMC test lab and
    consultancy that offers practical advice and EMC problem solving for a wide
    range of electronics products.
— The complex and simplistic elegance of the 1-wire protocol
The Dallas 1-wire protocol is a two-way communications bus that allows
microcontrollers to talk to a number of peripherals using just a single wire. It
promises high data rates, a range of peripheral types and very long wires all
with the minimum of resource requirements and complexity. This talk will explore
how it works, how to implement it and how to actually drive those busses made up
of very long wires.
  • Andy Bennett trained as an Electronic & Electrical Engineer and has a
    background in consumer electronics, FPGAs, operating systems and device drivers.
    For the last 10 years he has been building companies around distributed database
    technology. He is currently Director of Register Dynamics who help companies and
    governments apply their data usefully, responsibly and ethically.
Andy is a Technologist that likes to inhabit the void between users, software
and the hardware that it all runs on. His love of ceramic taps is
well-documented.
*** Sunday :: Workshops ***
— Customising a RISC-V Core - workshop
Starting from an Open-source RISC-V core, add a new instruction to it that you
design! This workshop will walk through the process of getting started with
simulating an open-source RISC-V core and making the necessary modifications to
decode and execute a new instruction.
A processor that supports a new instruction is not much good if you can’t write
any code for it, so the second part of the workshop will focus on adding support
into the assembler for your new instruction, so that you can write a program
using the instruction and see that it executes correctly (or does not, and helps
you to work out the bugs in your implementation).
The tutorial materials will provide enough of the implementation and sufficient
guidance to be able to work through with a little experience of Verilog and C++.
For those new to Verilog, the materials from last year’s talk and workshop
(“Introduction to cycle-accurate Verilog simulation” and “Open Source RISC-V
core quickstart”) will be available to provide a more accessible starting point.
Participants should bring:
  • A laptop
  • Run by: Graham Markall
— A Crash Course in KiCAD
A KiCAD basics workshop that will be a crash course covering the main aspects of
schematic capture, PCB layout and generating the manufacturing outputs and 3D
models etc.
  • A laptop with KiCAD version 5 installed ready to go.
  • Run by: Tim Telford
— Gigatron TTL Computer demo and hands-on
There will be a demo of the machine and an opportunity to do some
retro-programming.
  • Run by: Ken Boak
— SMD Soldering
In this workshop we will introduce common SMD soldering techniques, including
stencils and solder paste usage in a hobbyist home-lab capacity. The format is a
series of demonstrations followed by exercises. Participants will be provided
with a kit of parts and will assemble their circuits taking turns on the
equipment provided. There will be a mixture of hand soldering and hot plate/air
reflow techniques covered and a variety of SMD packages including some fine
pitch components will be used.
Participant requirements:
  • Some familiarity with soldering and electronics in general would be
    beneficial.
  • Run by: Omer Kilic
— Assembling Your RC2014 Z80 Based Computer
This workshop will take participants through all the stages of assembling and
getting started with the RC2014 kit. Some basic soldering experience is assumed
and soldering irons and tools will be available for groups of up to 6 people at
a time.
There will be a nominal charge of £5 per person.
  • A laptop.
  • An FTDI cable if they have one.
— Heterogeneous embedded hardware example walk through
A walk through a practical heterogeneous application and its development, based
around the combination of a microcontroller and an FPGA along with mixed
tooling.
  • Run by: Alan Wood
NOTE:
  • There are separate tickets for Saturday and Sunday.
  • A light lunch and refreshments will be provided each day.
  • Delegates will receive an RC2014 Micro upon registration on the Saturday
  • Please aim to arrive between 09:00 and 09:15 on the Saturday as the event will
    start at 09:20 prompt.
