Pinball controller box
How do.
Does anybody have any experience building arcade machine controllers
(Paul/Tallscreen has a cabinet if I am not mistaken)?
I am hoping to build a full arcade cabinet eventually but in the
meantime I fancy building a Pinball Controller. Should be fairly
simple with just the plunger and a few buttons for the flippers/
nudging etc. (or perhaps even an accelerometer for the nudging?!)
This is the sort of thing I have in mind - http://www.nanotechent.com/pinball-wizard.php
If anyone else is a pinball geek like myself then you are probably
already aware of http://www.futurepinball.com/ and http://www.randydavis.com/vp/intro.htm
with which I intend to use the controller.
Possible project for the hackspace I guess - If anyone has any
pointers on where to start I would be grateful :smiley:
Scott
Yup! :slight_smile:
By nudging, do you mean like a ‘tilt’? You can probably use a cheaper
mercury switch.
This is the sort of thing I have in mind -http://www.nanotechent.com/pinball-wizard.php
The flipper buttons on that look like standard arcade buttons.
I’m guessing the buttons just emulate a PC keyboard? You can just hack
a keyboard apart and wire up the buttons, but you can sometimes get
problems with interference (not so much on modern keyboards), and
’ghosting’. A more elegant solution, which is what I did, is to buy a
keyboard encoder (http://wiki.arcadecontrols.com/wiki/
Keyboard_Encoders). I used a (now obsolete) iPac.
Not sure where you’d get a plunger though!
For the actual pinball plunger, I’ve seen a machine that used a
replacement plunger (which you can get for next to nothing on ebay)
connected to an optocoupler, an attiny for detecting how long the
plunger has been pulled back (for release speed), and a relay for
switching an input on an i-pac or similar interface.
As far as interfaces go, the main problem with using a PC keyboard’s PCB
is that they use a matrix, and therefore you can get ‘ghost keys’ when
too many keys are pressed at once (i think the limit is 3 or 4 on a
modern keyboard).
If you want, i can bring along some parts to the next meeting for us to
prototype one, as i have a bunch of parts i bought years ago for an
arcade machine that i’ve still not built, including some buttons and an
i-pac, and i’m sure i can dig out an optical sensor from somewhere :smiley:
If someone fancies bringing along a laptop with some pinball software on
it, we might even be able to have a game or two :smiley:
Yup! :slight_smile:
mercury switch.
Wow thanks guys. I’ll bring my laptop along with the pinball machine
software then. Will try to get some research done into your suggestions, it
will also help when I get round to sorting a full cab out as I will probably
be putting the same pinball controls onto that too.
As for the mercury switches for tilting, is there some way to rig a few of
these to sense the direction of the nudge? The emulation just maps nudges to
a button so sensing the force of the shove isn’t important.
Forgive my ignorance, I’ll be doing some proper research in the meantime :D2009/10/9 Bob Clough parag0n@ivixor.net
modern keyboard).
Yup! :slight_smile:
mercury switch.
http://stockport.hackspace.org.uk/user/files/tiltswitched.png
1 and 2 show how a tilt switch works. Its essentially a can, with a
drop of mercury in it, and two contacts. When the mercury shorts the
two contacts, the circuit is made, and you know its at the set angle.
  1. shows how you would set up two sensors so that you know the direction
    of a tilt. When it is tilted left, the right hand switch will activate,
    and vice versa. This can be tuned simply by adjusting the angle the
    switches are at.
I’ve seen a couple of boards that use accelerometers to detect nudge,
and think this might be a better way to do it, especially if you already
have a microcontroller lying about for your plunger. We may be able to
make a board using v-usb (ATMega software USB) on an atmega8 in keyboard
mode, so we can completely skip the extra keyboard encoder!
I’ll have a dig around in my bits box, see what i can come up with :slight_smile:
suggestions, it will also help when I get round to sorting a full cab
out as I will probably be putting the same pinball controls onto that
too.
few of these to sense the direction of the nudge? The emulation just
maps nudges to a button so sensing the force of the shove isn’t
important.
meantime :smiley:
    For the actual pinball plunger, I've seen a machine that used
    a
    ebay)
    the
    for
    keyboard's PCB
    is that they use a matrix, and therefore you can get 'ghost
    keys' when
    on a
    modern keyboard).
    for us to
    for an
    arcade machine that i've still not built, including some
    buttons and an
    i-pac, and i'm sure i can dig out an optical sensor from
    somewhere :D
    software on
    it, we might even be able to have a game or two :D
    controllers
    > Yup! :)
    in the
    fairly
    flippers/
    nudging?!)
    > By nudging, do you mean like a 'tilt'? You can probably use
    a cheaper
    > mercury switch.
    buttons.
    > I'm guessing the buttons just emulate a PC keyboard? You can
    just hack
    sometimes get
    keyboards), and
    > 'ghosting'. A more elegant solution, which is what I did, is
    to buy a
    > Not sure where you'd get a plunger though!
