Pledge Run - Large Ultrasonic Cleaner
I’m thinking of doing a pledge run for a larger Ultrasonic Cleaner
  1. In built Heater (I’ve discovered that heat is very important for it to work)
  2. Ability to re-use the cleaning fluid (since putting cleaning fluid in the kettle is probably a bad idea)
  3. In built timer (it’s best to run them in 10 / 15min bursts with 5min rest in-between)
  4. Includes a drop in cage
I’m thinking of going for the 15L one which would be 300mm x 300mm x 150mm deep
which would come to around £124
I’ve found if you use stuff like this - https://www.amazon.co.uk/gp/product/B001WL5IGC/ with hot water then hit it with a brass brush afterwards, it looks like it’s been polished.
I’ll be away between the 13th to the 20th so if I order one it’ll have to be after then
Richard
I’ll kick in 20 quid :slight_smile:
What stuff you thinking of cleaning?
I recently picked up a relatively cheap uc and frankly, it’s not wonderful. My use case is cleaning circuit boards, cleaning of flux residue etc.
Apparently there are very expensive ones using a sweeping frequency which works considerably better.
Mine is this one:
Commercial Ultrasonic Cleaner-DK SONIC 6L 180W Sonic Cleaner with Heater Basket for Jewelry,Denture,Coins ,Metal Parts,Carburetor,Fuel Injector,Record,Circuit Board,Brass etc https://www.amazon.co.uk/dp/B07BL1RP4P/
My opinion might change when I get around to using the special solution that goes into the deionized water for pcbs but I somehow doubt it.
Mostly metal stuff (parts for a lathe I’m working on)
the one you linked is too small for me, I’m aiming for 15L ideally
we already have a small one at the moment (although it doesn’t have a heater or sweep or anything like that)
Just had a reply from Matthew Nixon on telegram - £10 towards it
OK. £10
