Now I’ve got my nice new shiny scope I’ve been playing around with the
piezos I used as a drum triggers.
Firstly, it turns out that piezos have an orientation - hit them on one
side and you get an initial large +ve spike followed by an irregular
decaying AC signal. Turn them over and you get a large initial -ve
spike. The ones I’ve got have random orientations - the black/red leads
tell you nothing about what the orientation is.
I was using this circuit:
http://leucos.lstilde.org/wp/wp-content/uploads/2009/05/piezo_circuit.png and
hindsight, with even my limited electronics knowledge, it seems like a
load of tosh - full article is at
http://leucos.lstilde.org/wp/2009/06/piezo-transducer-signal-conditioning/
Here are what I think are the problems, do they seem valid?
The 2nd BAT85 (schottky) from the left serves no purpose as it is in
parallel with the 5.1V zener. -
The RC pair are supposed to be providing smoothing but they are in
parallel, a configuration that as far as I’ve been able to find out just
adjusts the phase of the current through the capacitor. I think what is
actually needed is a RC low-pass filter. -
The circuit is intended to protect the input of the MCU not just
against +ve overvoltage (the zener) but also -ve voltages (the 2 BAT85s,
one of which is redundant). However, by observation it doesn’t do that.
I’ve simplified the circuit so it just has a single BAT85 to protect
against -ve voltages and no other components.
The first image below (pos.png) shows what happens with a large +ve
spike and is as expected - the input voltage (red) initially goes +ve
and the post-diode voltage (yellows) follows, then when the input
voltage goes -ve the diode prevents its output voltage from going below
0V, as expected - well, mostly, it still goes to -1.6V, not sure why.
However if we flip the piezo over and generate a leading -ve pulse we
get a -ve output from the diode that’s way beyond what we’d expect
(neg.png), -22.4V in this case. This puzzled the hell out of me until I
looked at the BAT85 datasheet. The max reverse voltage is specified as
30V, here it’s having -74V stuffed across it. The BAT85 is completely
unsuitable for the job, I’ve seen spikes of over 100V from the piezo, so
a diode with a VR of 200V is probably what’s needed.
Does all that seem correct?
