Proposal Type:
Micro
Proposer:
Peter Roberts Wood Team/Board
Description:
New blade for parkside saw because I’d like to establish if the thing is broken or just needs a new blade. If it’s working we might as well keep using it until it is.
New chucks for dremels because I broke one the other day. I ordered a set with ones that allow you to use a spanner for tightening because I’ve found those better. Not sure what the amazon link will go to but I ordered the option that said it was the dremel size rather than the generic one.
To be honest I’ve already ordered and received these things, so this is more of a reimbursement proposal. Supporting as an ordinary member to avoid accusations of rampant corruption on the board etc.
Proposed Purchase:
New blade for Parkside Plunge saw: Saxton TCT Circular Wood Saw Blade 165mm x 20mm (16mm Ring) x 48 Teeth Compatible with Bosch Makita etc : Amazon.co.uk: DIY & Tools
New chucks for Dremels: Drill Chuck Collet Set, 15Pcs Chuck Collet Kit for Rotary Tool, 0.8-3.2mm Shank Replacement 4486 Keyless Quick Change Chuck Accessory with Replacement 4485 Brass Collet Metal Nut : Amazon.co.uk: DIY & Tools
Proposed Installation:
Chucks would go in rotary tool accessories drawer
Blade would be attached to the Parkside saw
Budget:
£22.98
Funding type:
Fully funded by Hackspace
Health & Safety
Covered by existing processes
Supporters
Micro Proposal <£50 - 1 Board Members and 2 Members
Supporting Board Members:
