Purchased! - Woodwork tool replacement parts
Proposal Type:
Small
Proposer:
Mark Dale - WoodyDusty
Description:
We currently have a few tools out of service due to various faults. This list details all the parts needed to restore them to working order. Additional stock are included in the proposal to save time in future.
Pillar Drill
The pillar drill is made by Clarke, model number CDP5DD. Official spare parts are supplied by Machine Mart.
Forum Wiki Page: ~ coming soon ~
Major issues:
  1. Broken switch
The switch is a NVR however the exact type/size I am not sure about as we no longer have it. Buying it from 3rd party on eBay may be a few £s cheaper, however going via Machine Mart should guarantee we get the correct item without any hassle.
Part No. Description Unit £ Qty Supplier
ZHC5067 Switch £14.63 1 Machine Mart
Minor issues:
  1. Missing one of three handles
The machine is currently missing one of the control arms that are used to lower the drill chuck. These arms simply screw into the shaft. While only one set is needed (Handle & Tip), as the price is quite cheap, I’m proposing buying three sets so we have spares for future.
ZHC5034 Handle £0.84 3 (1) Machine Mart
ZHC5035 Handle Tip £0.82 3 (1) Machine Mart
Changes to consumables:
None
Belt & Disc Sander
The belt & disc sander is made by Clarke, model number CS4-6D. Official spare parts are supplied by Machine Mart. The machine is on-lone by a member.
Major issues:
  1. Drive belt snapped
Drive belt for the Sanding Belt has snapped. This seems to be a frequent fault as it has failed twice within a few months, assumed due to members pushing too hard on the sanding belt. One challenge with sourcing parts is Clarke have three variants of this machine each with slightly different drive belts which are easy to mix up when ordering. 3rd party suppliers are available however the price saving is quickly lost when additional shipping costs are accounted for. Only one belt is required, however I’m proposing we buy three to keep stock for future to save on shipping costs.
  1. Broken belt guard plate
The belt guard plate is a thin sheet metal part that covers the internal mechanism of the belt arm. The damage is where a mounting bracket has sheared off and due to the material thickness, this cannot be fixed. Only Machine Mart can supply this replacement. Only one part should be needed, this guard doesn’t have a reason to be removed for normal operation.
ZPT150XL037 Drive Belt £6.12 3 (1) Machine Mart
ZAWNCS46E94 Protection Plate £9 1 Machine Mart
Minor issues:
None
  1. Sanding Discs
The disc sander part of the machine has previously had a Velcro pad glued to it allowing for quick change of sanding discs. This Velcro has been destroyed as members have tried to use it to sand. To simplify and avoid this kind of issue in future, the proposal is to revert back to having glued on sanding discs with one standard grit (80) fitted. A pack of 10 discs cost £4.75 from Amazon. This should then be easier for maintainers to replace when it get worn.
Bobbin Sander
The bobbin sander is made by Triton, model number TSPS450. I couldn’t find an official spare parts supplier, however Tool Spares Online appear to have all the parts for Triton tools:(http://www.toolsparesonline.com)
Major Issues
  1. Drive Belt Snapped
The bobbin sander has two drive belts that control the spindle spin and the vertical movement. The belt controlling the vertical movement has snapped and appears to have a few points of failure starting. The main drive belt appears fine for now. While only one belt for the vertical movement is required, I’m proposing buying three of each belt for future spares and to save on shipping.
(13) 585529 Belt I (10mm) £5.30 3 (1) Tool Spares Online
(14) 283424 Belt II (6mm) £4.22 3 (0) Tool Spares Online
Minor issues:
None
None
Budget:
Two orders need to be placed, one with Machine Mart and one with Tool Spares Online
Machine Mart
Machine Mart have a minimum £9 delivery fee, require payment at order and issue invoice on part delivery. Not sure if ‘Click & Collect’ is possible to reduce this fee as we have a store in Openshaw (M11 1AA) we could collect from.
Total + P&P = £55.97
Tool Spares Online
Tool Spares Online have a minimum £5.95 delivery fee.
Total + P&P = £34.51
Combined Total £90.48
Funding type:
Fully funded by Hackspace
Health & Safety
No change to Health & Safety
Supporters
Small Proposal < £150 - 2 Board Members and 5 Members
Supporting Board Members:
  1. Joe
  2. Frank
  1. Mark
  2. Mike
  3. Peter
  4. Guy
If you’re not sure how it works from here, basically below you can ask any questions you have, then once you’re happy for the proposal to go ahead you can reply showing your support. This can be as simple as posting “+1”.
Mark (@Marcus6275)
I support this. Cheers Mark for putting the list together
+1
Thanks for putting this together. I support all of these purchases.
Hiya Mark,
Sounds good to me. Thanks for taking the time to put this together.
Board +1
Thank you Mark for all your efforts.
Aye.
You’ve done a lot for woodworking, thanks on behalf of everyone!
Thanks all, orders placed, will update when machines are operational again.
PSA: don’t ring Machine Mart directly for ordering spares, its a charged line so use the email instead: Machine Mart - Machine Mart
This topic was automatically closed after 27 days. New replies are no longer allowed.
