right paper for pcb's?
hi all,
quick question: which would be the right paper to use to do circuit
transfers to pcb’s?
thanks for the help. :slight_smile:
cheers,
const
Constantine,
I have found through experience that 120GSM matt coated paper works the
best. Some people claim glossy magazine paper works well but I haven’t
found this to be the case.
Good Luck
AlexOn 23 April 2014 20:05, Constantin Popp constantin.popp@gmail.com wrote:
hi all,
transfers to pcb’s?
cheers,
const
cheers alex,
will try that out. also, did anybody try using acetate to rub the toner off
the paper rather than using heat? would this work, too?
constOn Wednesday, 23 April 2014 21:48:24 UTC+1, Alexander Lang wrote:
Constantine,
Good Luck
On 23 April 2014 20:05, Constantin Popp <constan...@gmail.com<javascript:> wrote:
hi all,
transfers to pcb’s?
cheers,
const
To post to this group, send email to hac...@googlegroups.com<javascript:>
Not quite sure what you are meaning using acetate to rub the toner off…I
think it only responds to heat…
Try it and let me know!
AlexOn 24 Apr 2014 13:05, “Constantin Popp” constantin.popp@gmail.com wrote:
cheers alex,
off the paper rather than using heat? would this work, too?
const
Constantine,
Good Luck
On 23 April 2014 20:05, Constantin Popp constan...@gmail.com wrote:
hi all,
transfers to pcb’s?
cheers,
const
hi alex,
and the answer is: it doesn’t work with pcb’s.
though it does work with paper well. have a look at the photo:
https://lh6.googleusercontent.com/-XhfR2D-ZK4Y/U1piTsU19LI/AAAAAAAAAbQ/3E3e-HRlvRc/s1600/DSC_0024.jpg
i was using some paper towel wet with acetate and used it to rub the toner
off the paper. the paper will absorb this toner, not the copper though.
similar to heat, the acetate will dissolve the toner’s glue momentarily. i
guess the copper is not absorbing enough, hence the actetate method doesn’t
work.
anyhow. it was worth a try though.
bests,
off…I think it only responds to heat…
On 24 Apr 2014 13:05, “Constantin Popp” <constan...@gmail.com<javascript:>> wrote:
cheers alex,
const
Constantine,
Good Luck
hi all,
transfers to pcb’s?
cheers,
const
