Space security
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA512
Hi Guys,
When I arrived to open MadLab on Saturday morning at about 8am I was rather distressed to find that the shutter for 42 was up and the main door was ajar.
I checked the space, and all the other doors in the building at the time, there was no one there and fortunately no harm was done, however on my way back out I realised we were still marked as in.
If you are the last person out of space:
Check the building!
If there’s no one else in (don’t forget to check the toilets) please make sure you shut the door fully and close/lock the shutters.
If there is someone else in the building make sure you mark us as OUT so they know they can close the shutter when they leave.
(Should we have a sign to this effect on the back of the door?)
tamarisk kay
Insanity is repeating the same mistakes and expecting different results.
Basic Text of Narcotics Anonymous, 1982
-----BEGIN PGP SIGNATURE-----
Comment: GPGTools - https://gpgtools.org
iQEcBAEBCgAGBQJTJyDnAAoJEEneiR4sEu0yC6wIAIjDvZAnYTEZvWgyq0Gu0KnS
cBZHWxNNM1CT98NuRNvF1vB/Z81bIbKFGz1d8cqvgsUTsamUZ1oLz6y9/Phe6DiE
O89K3D9wX7ZvpckvlCij4U6gj0ZULE0fdZL6lFXseceIu6OPhziItroC9hqGwori
3f1J0SPNFA18Jo1rWEZDD81y+1NDEMUK0F51Lu1yqMLr1RJtVYJCKTw6AJ1ncQkb
X1wxz1qF6iqpo2OMIGHRiF5u+aL7txgU/X/5M6Jvvh+mP5SRdilpeC3yiWg4Tvsg
s40B/EvyMekN3Dmae7G+LwcP2ppH4pewc5zr4Kbrbzer5rK5eFoehrPdHlsLtm4=
=pX/T
-----END PGP SIGNATURE-----
There are two things that we could do:
  1. All new members could be given a “handbook” which points important
    stuff out to them like the procedures for leaving the space. It’s
    likely that the last person to leave just didn’t know about the
    temporary shutter key.
  2. The outside door needs to be fixed. Right now it only reliably
    closes when it’s slammed and checked, and this sort of stuff is going
    to keep happening while that is the case. People are fallible.
Hash: SHA512
Hi Guys,
Check the building!
tamarisk kay
=pX/T
I thought the front door lock had alreadycbeen changed?
Will.
Hash: SHA512
Hi Guys,
was ajar.
Check the building!
tamarisk kay
Anonymous, 1982
=pX/T
I don’t know about likely, possible certainly although I do make a point of trying to make sure everyone knows of the existence of the emergency key. It’s equally possible that they weren’t in fact the last person to leave the building as a whole and that the shutter was left up by someone unrelated to backspace.
  1. The outside door needs to be fixed. Right now it only reliably
The front door lock is an ongoing saga. The last time someone from building maintenance did anything about it they rendered it impossible to close for about a week until someone came to “un-fix” it.
This is not about approbation of blame it’s about trying to make sure that it doesn’t happen again.
So moving forward:
I am planning to print and laminate “last one out” type instructions for the inside of the door to hackspace. Things that need to be on the list:
Check benches are isolated, all equipment turned off etc.
Check everything is turned off in the kitchen (coffee pot, hot plate etc)
Turn off lights in the quiet room and clock (remote to your right), turn off main lights
Check the building on your way out:
Anything else?
T.
Will.
  • -----BEGIN PGP SIGNED MESSAGE-----
    Hash: SHA512
Hi Guys,
Check the building!
tamarisk kay
=pX/T
  • -----END PGP SIGNATURE-----
iQEcBAEBCgAGBQJTKDWoAAoJEEneiR4sEu0yBA0H/jtn03fsnYY88jjLHRBIjzUm
clE47Cj2KfK/rL8dIdKOGoocZsEUhu2Dd73SDXkiCfz4Nke7DxtzMynyEfVRdQkA
VZVaOO6syP7kZ3GeIAjNVBU+DuKnD/aYtsDAASdcqk5mDpcPdW1eb+Dxhe/aXk/G
PeYRw3fap0YdSnOOdNcGDuzIW3PksImO9sNVjzks0BlWVYcznAImgsxqHqWSerne
wWveYFSX2+WV3nlWua1j6/xcEwWNdDSNGH71U6IbCVqUfArHxqw2Alcd0v6NLyxK
MJKRI9xO7i5VhC8lSukz4xrtbn9vvOC1rLwAHfl3I+amzICZJKHxwn7vQHQaSIk=
=W8HL
I’m thinking we also need to add a general sign to the back of the front
door, and the column to your right as you come in, with
“PLEASE CHECK THE FRONT DOOR IS CLOSED BEHIND YOU, SOMETIMES IT DOESN’T
LATCH PROPERLY”
Or something to that effect.On 18 March 2014 12:01, tamarisk kay tamarisk.kay@gmail.com wrote:
Hash: SHA512
So moving forward:
off main lights
Anything else?
T.
Will.
    Hash: SHA512
Hi Guys,
was ajar.
Check the building!
tamarisk kay
1982
=pX/T
=W8HL
