stock count in farnell + pcb cnc?
hi all,
did anybody else had that problem, too, that the uk stock count in farnell
is really low? it seems to always suggest buying things from the us.
also, i would like to learn how to fabricate a pcb using the hackspace’s
cnc mill. are there some induction materials around to learn how to use it
once i know how? would it be ok if i were to use it?
hope you are all well.
bests,
const
Constantin…
which components are you trying to order that are not in stock? There are
nearly always UK alternatives it just depends on which boxes you tick when
using Farnell’s awesome (sarcasm) parametric search function. If you click
exclude extended range that removes all US stock which then should reduce
the number of available choices and then it’s luck if it is in stock. If
Farnell don’t have it there are other vendors that do.
There is not yet an instruction set for the CNC mill. Bob has it on his
todo list…which is a very long list. I can chemically etch a PCB for you
if you are desperate.
AlexOn 26 May 2014 16:14, Constantin Popp constantin.popp@gmail.com wrote:
hi all,
bests,
const
hi alex,
“extended range”. thanks. was looking for this option!
with regard to the PCB etching. thanks for the offer. i think i’ll pick you
up on that for the next pcb. cheers. with the previous pcb i did i wasn’t
happy with my drilling of the holes. and i also left the etchant on for too
long. it just did not look professionally. so i hoped with proper cnc’ing
it’ll look better. :slight_smile:
constOn Monday, 26 May 2014 17:28:22 UTC+1, Alexander Lang wrote:
Constantin…
On 26 May 2014 16:14, Constantin Popp <constan...@gmail.com <javascript:>>wrote:
hi all,
farnell is really low? it seems to always suggest buying things from the us.
bests,
const
To post to this group, send email to hac...@googlegroups.com<javascript:>
Don’t worry Constantin…
If I make it, it will look professional!
promise!
AlexOn 27 May 2014 14:50, Constantin Popp constantin.popp@gmail.com wrote:
hi alex,
you up on that for the next pcb. cheers. with the previous pcb i did i
wasn’t happy with my drilling of the holes. and i also left the etchant on
for too long. it just did not look professionally. so i hoped with proper
cnc’ing it’ll look better. :slight_smile:
const
Constantin…
are nearly always UK alternatives it just depends on which boxes you tick
when using Farnell’s awesome (sarcasm) parametric search function. If you
click exclude extended range that removes all US stock which then should
reduce the number of available choices and then it’s luck if it is in
stock. If Farnell don’t have it there are other vendors that do.
On 26 May 2014 16:14, Constantin Popp constan...@gmail.com wrote:
hi all,
bests,
const
