I’m toying with the idea of buying a digital storage scope. Would a
100MHz one be fast enough for AVR-type stuff? A bit of googling says
the answer is probably ‘yes’ but I thought I’d ask
Alan,
The most important specifications on an oscilloscope are:
Analogue Bandwidth
Max Sample rate
Number of input channels
Max sample memory
Everything else is less important…For what you would be using it
for a 100MHz scope will probably be fine as long as it’s a well made
scope from a reputable manufacturer and not a one hung low USB
scope…You get what you pay for with instrumentation and the best
stuff always costs the most. The RIGOL scopes that were hackable were
pretty good scopes for what you get.
Regards
AlexOn 13 October 2012 18:28, Alan Burlison alan.burlison@gmail.com wrote:
I’m toying with the idea of buying a digital storage scope. Would a 100MHz
one be fast enough for AVR-type stuff? A bit of googling says the answer is
probably ‘yes’ but I thought I’d ask–
Alan Burlison–
Sorry to tag onto somebody’s post, but this is quite similar
I need a portable scope or scopemeter (scopemeter I think would be better)
It is for looking at LED PWM waveforms on lights / matrices (disco and
stage lights) when put up / assembled
Being 15, I have very little money, so no flukes
I am looking at the uni trend UT81b and the DSO nano
I am leaning towards the uni trend - am I being an idiot, or is this the
way to go?
George
(Yes, I will be coming back in with the LC parts for teh printer, robotics
team crap has gotten in the way, sorry)On 14 October 2012 21:00, Alexander Lang alexanderlang1980@gmail.comwrote:
Alan,
Analogue Bandwidth
Max Sample rate
Max sample memoryEverything else is less important…For what you would be using it
pretty good scopes for what you get.Regards
100MHz
answer is
Alan Burlison–
http://groups.google.com/group/hacman?hl=en-GB.–
George,
This is a difficult question to answer. It depends on a lot of
things…Normally this is about what you need the scope to do or
rather what are you using the oscilloscope for.
I’m not a great fan of the handheld meters but I accept that they have
a place and I may yet buy one! Hey, I bought one of these and it does
work but it isn’t the best:
http://www.coolcomponents.co.uk/catalog/xmega-xminilab-oscilloscope-p-843.html
I like the look of the nano but I can’t say whether it would be any
good or not. The Uni-trend looks good too although I would be happier
with better analogue bandwidth.
I would read up on scopes and then make a decision. I prefer bench
scopes. My Mrs bought mine off ebay for £50…best thing she ever
did.
Best of Luck,
It is for looking at LED PWM waveforms on lights / matrices (disco and stage
lights) when put up / assembledBeing 15, I have very little money, so no flukes
I am leaning towards the uni trend - am I being an idiot, or is this the way
to go?Thanks,
George
team crap has gotten in the way, sorry)On 14 October 2012 21:00, Alexander Lang alexanderlang1980@gmail.com wrote:
Alan,
Analogue Bandwidth
Max Sample rate
100MHz
answer is
Alan Burlison–
100MHz one be fast enough for AVR-type stuff? A bit of googling says the
100MHz is a pretty reasonable analogue bandwidth for the input.
Things to check for:
There’s also a few gotchas, such as if the probe inputs GND is connected
to Chassis GND or not (can cause short circuiting if not careful)
I like my TDS220, and people can borrow it at the space for a time as I’ve
left it there.
I use CRO scopes, and generally avoid handhelds.
This is for quick diagnostic on busted LED stage lights and if the matrix
ever decides to blow up in my face when set up at school. Mainly this will
consist of checking PWM waveforms for problems (what I gleaned from talking
to the HSL engineer, HSL is a massive lighting firm)
The specs are more than adequate for this; I was more looking for
more practical factors in usage, as I have no experience with them and only
a little with field testing, things such as battery life, display
visibility, ruggedness, size.etc
GeorgeOn 14 October 2012 22:00, Alexander Lang alexanderlang1980@gmail.comwrote:
George,
rather what are you using the oscilloscope for.I’m not a great fan of the handheld meters but I accept that they have
work but it isn’t the best:http://www.coolcomponents.co.uk/catalog/xmega-xminilab-oscilloscope-p-843.html
with better analogue bandwidth.I would read up on scopes and then make a decision. I prefer bench
did.Best of Luck,
better)
stage
way
to go?Thanks,
George
robotics
Alan,
Analogue Bandwidth
Max Sample rate
100MHz
answer is
Alan Burlison–
Groups“HAC:Manchester” group.
I thought I had covered that in the previous messages with Alan
although not as concisely. I agree with all Ben has mentioned
obviously!
answer is probably ‘yes’ but I thought I’d ask100MHz is a pretty reasonable analogue bandwidth for the input.
- Input sensitivity, what range(s) will it measure
- Sampling rate, should be at-least twice the input bandwidth.
- Triggering options and sources (some have external triggers)
- Sample depth, how much will it store pre and post trigger
- Post capture processing, such as frequency, pwm, fft on capture
- Post capture dump to PC or other mass-storage
to Chassis GND or not (can cause short circuiting if not careful)I like my TDS220, and people can borrow it at the space for a time as I’ve
left it there.–
Ben Dooks, http://www.fluff.org/ben/ bjdooks@googlemail.com–
If this is the case then the handheld trend is your best bet. It’s an
established product in a proper case with reviews available. The nano
is a bit of suck it and see device. Made by Hackers for Hackers
doesn’t mean it will be any good.
AlexOn 14 October 2012 22:23, Alexander Lang alexanderlang1980@gmail.com wrote:
obviously!Cheers
left it there.–
Time to hit ebay :-DOn 14 October 2012 22:26, Alexander Lang alexanderlang1980@gmail.comwrote:
doesn’t mean it will be any good.Cheers
obviously!Cheers
theanswer is probably ‘yes’ but I thought I’d ask
I’veleft it there.
Hmm just looked at a review of the DSO nano…not feeling the love.
It isn’t there yet and needs a bit more work.
I would seriously look at the trend.
AlexOn 14 October 2012 22:27, George Ainscough dashroom66@gmail.com wrote:
Time to hit ebay
obviously!Cheers
the
connected
I’ve
left it there.–
The only thing that was making me consider it was the nice screen, but I
think I am going to go with the trend.
GeorgeOn 14 October 2012 22:52, Alexander Lang alexanderlang1980@gmail.comwrote:
It isn’t there yet and needs a bit more work.I would seriously look at the trend.
Time to hit ebay
obviously!Cheers
saysthe
connected
I’ve
left it there.–
The TDS220 was the best $200 I spent in a while.On Oct 13, 2012 6:28 PM, “Alan Burlison” alan.burlison@gmail.com wrote:
To unsubscribe from this group, send email to hacman+unsubscribe@**
googlegroups.com hacman%2Bunsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/**
group/hacman?hl=en-GB http://groups.google.com/group/hacman?hl=en-GB.
The one I’m looking at is the Owon SDS7102, I think the following are
Looks like the minimum is 2mV per division, and then up to 400V
2 channels, each at 500MS/sec
Internal and external, AC, DC, rising/falling edge, pulse width
10M samples per channel, I think up to 50% pre-trigger
inter-channel arithmetic ops, FFT.
Yes, save internally, USB and I believe Serial
Not sure about that, the manual is a bit vague.
