TSSOP breakout boards
Hi guys,
Anyone know where to get a DIL breakout board for a TSSOP-16 ic?
I’ve managed to obtain a couple of Analog Devices AD9835BRUZ DACs (by
way of free sample) but I have no way to breadboard them. I have found
a breakout board at farnell but the pins are dual-row so they wouldn’t
be possible to breadboard.
Cheers.
personally (being extraordinarily lazy and a cheap git) I just get rows of
pin headers, and solder them to the IC with bare copper wire.
I put the headers into the breadboard, then put the IC onto something to
raise it up (usually cardboard) and tape it steady), then just go at it
with the iron and wire.
Hope that helps (it probably won’t)
GeorgeOn 13 July 2012 21:28, Rowan Wilson rowan.i.wilson@gmail.com wrote:
Hi guys,
Cheers.
Would this do the trick?
http://www.proto-advantage.com/store/product_info.php?products_id=2200038&gclid=CMH20e3Cl7ECFcgntAodNwg0RwOn Fri, Jul 13, 2012 at 10:44 PM, George Ainscough < dashroom66@googlemail.com> wrote:
George
Hi guys,
Cheers.
http://www.ebay.co.uk/itm/2pcs-SOP16-TSSOP16-SSOP16-To-DIP16-Adapter-Convertor-/150632038323?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item23125e7fb3#ht_940wt_702
from hongkong though, so may take weeks!On 13 July 2012 21:50, Darren Burrows darren.burrows@gmail.com wrote:
of pin headers, and solder them to the IC with bare copper wire.
George
Hi guys,
Cheers.
More expensive but easily available
http://uk.rs-online.com/web/p/prototype-development-boards/4632853/?origin=PSF_118398|cavOn Fri, Jul 13, 2012 at 9:54 PM, Bob Clough parag0n@ivixor.net wrote:
On Fri, Jul 13, 2012 at 10:44 PM, George Ainscough dashroom66@googlemail.com wrote:
raise it up (usually cardboard) and tape it steady), then just go at it with
the iron and wire.
George
Hi guys,
Cheers.
Hi guys,
I might have a couple at home, but I’m not going to be around until
25th.
