A few months ago the table saw was damaged after the slide carriage fence was pushed though the saw blade. As a result of this I took the machine out of service so that I could assess the extent of the damage as well as ensure that if it occurs again we have a plan.
First thing to address is that the saw doesn’t have any official training and as it is significantly more complex than the smaller Evolution the woody team have decided that all members will require new training on this saw. The woody team hope to have the training available soon so please bare with us. The table saw will be fitted with a lock out plug and anyone found tampering with it will be reported to the Board.
Damage
From appearance alone the extent of the damage appears to be limited to the slide carriage fence and a couple teeth on the blade. The fence also had a ‘sacrificial’ plastic piece that was completely chopped off that will need replacing.
Pics of the damage:
Slither of the extension bar found inside of the main slide fence…
The woodwork team intend to apply a fix to the main fence that will stiffen it since the majority of its structure has been lost.
Parts we need to replace
While checking the machine I found that we were missing several parts. Most of this was the nuts and bolts used to adjust the fences. It is crucial that when members adjust the machine they look out for the fixings as without them the table saw looses it’s effectiveness.
I found that we need the following items (descriptions from NMA quote below):
5300 2700 - Sliding Ledge (x2)
5300 2611 - Angle (x2)
0500 3609 - Spring 7.56 / 6.44 / 0.56 X 12 41/5/1 (x2)
5320 6213 - End Piece for Stop Rail
7939 0218 - Threaded bolt for Rip Fence
0500 6441 - Wing Screw M6x25 Peltzer
0500 6311 - Wing Nut M6
Contacting Supplier
I have been contacting the spare/replacement parts supplier NMA (https://www.nmatools.co.uk/) for the past few months trying to get hold of prices and information on our saw. On Tuesday (yesterday) I finally received a pro forma invoice from them for most of the part’s I enquired about.
I sent over a marked up version of the parts list drawings:
TS2500 Hacman Parts Request.pdf (550.1 KB)
Green = Parts knowing to be either damaged or missing
Orange = Parts at risk of damage / information & price requested
Quote received:
NMA Quote 45681.PDF (104.5 KB)
The quote did not contain prices for all the items highlighted in the PDF I sent, and for some they were only available as a combined unit… eg the slide carriage fence (pictured above) would cost £180 to replace. I don’t currently intend to keep asking for this information as only
Going forward
With this information the woody team is now deciding how to proceed and what to purchase. Currently we expect the cost before Tax and Shipping will be over £30. This might be possible to reduce as it contains standard fixings such as M6 wing nuts.
NMA haven’t specified delivery times so when we will be able to get the machine suitable for use again is currently unknown, an update will be posted once the order is placed. For reference in the past when buying the riving knife it took 3 weeks for delivery.
