hey alex and rowan,
thanks a million for the further suggestions.
not sure if the logic level shifter is what i need. the wiz820 module would
be hooked up to a teensy 3.1 which operates in 3.3 v. so the logic signals
between the teensy and the wiz820 would be the same. the thing is that i
can’t power the wiz820 module from the teensy directly as it doesn’t
provide enough current (the wiz820 consumes up to 170 mA - the teensy only
allows up to 100 mA). but it does pass through the voltage coming from the
usb. hence my idea of putting some kind of magic voltage changer in there.
but maybe that’s not really possible in the end anyways. there’ll also
be 16 multiplexed leds, 1 led, 4 to 5 multiplexer ic’s and a small lcd
display. i guess that’s too much for the 500 mA from the usb anyways…
(will have to calculate that, too.)
good tip with the breakout board though. i just had a look at the
breadboard power supply board from sparkfun. for the final design i would
just have to incorporate it’s schematics in the complete design. hm…
thanks for the tips, too, rowan. i’ll have a look for this, too. and thanks
for the power/heat dissipation formula. very useful.
cheers,
constOn 20 May 2014 14:31, Alexander Lang alexanderlang1980@gmail.com wrote:
Constantin you need a logic level converter…not a voltage regulator.
You can use resistors or transistors or a special integrated circuit for
this purpose:
http://www.adafruit.com/datasheets/sn74lvc245a.pdf - a device for
performing the logic level conversion - Easiest method
http://letsmakerobots.com/node/34444 - a circuit using transistors and
resistors for performing the conversion - Hardest method
https://www.sparkfun.com/products/12009 - a premade breakout board using
a similar circuit for performing the conversion - Another easy method
I would suggest buying a breakout board for doing what you require…
On 20 May 2014 13:11, Constantin Popp constantin.popp@gmail.com wrote:
hi ben and alex,
thanks for the recommendations. will have a look at these.
i wonder, though, if there might be a better way of dealing with this. i
would like to use the wiznet5200 controller (within the wiz820 package)
powered by usb. so i thought i need to convert the usb’s 5v to 3.3v the
wiznet wants. is there a more efficient way to do the power conversion
without having to heat the room due to voltage regulation?
cont
https://groups.google.com/d/topic/hacman/tSVCTGkhcSo/unsubscribe.
